Interior & Equipment
Steering Columns
Issue with reverse lights
Topic: Issue with reverse lights (Read 10956 times)
K20Wulf
May 19, 2011, 03:22:18 am »
Okay, so the problem is; when I put my truck in reverse I can wiggle the column shifter and they will go on and off. I know it's probably a connection of some sort, but know idea of which one or how I would go about fixing it. Any help would be much appreciated.
86 K20 4x4
7" lift, 35's
350/400/208
jaredts
Re: Issue with reverse lights
May 19, 2011, 08:00:58 am »
Could just need an adjustment on your neutral start switch. Is there a lot of slop in the shifter?
May 19, 2011, 09:53:02 am »
Grim 82
May 19, 2011, 11:59:46 am »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=20206.msg164341#msg164341
jaredts
May 19, 2011, 01:15:28 pm »
Stupid? I resemble that remark.
May 19, 2011, 01:33:46 pm »
me 2
K20Wulf
May 19, 2011, 02:43:20 pm »
Thanks guys, I'll try and climb under there before work and see if I can adjust it.
86 K20 4x4
7" lift, 35's
350/400/208
May 19, 2011, 04:43:49 pm »
its on your steering column
K20Wulf
May 20, 2011, 05:42:53 am »
I meant climb under the dash. With the height of my truck it's literal, lol.
86 K20 4x4
7" lift, 35's
350/400/208
May 20, 2011, 10:02:58 am »
lol, it will take you a while to try and find it under the truck, you might need a torch
K20Wulf
May 26, 2011, 04:44:03 pm »
Quote from: jaredts on May 19, 2011, 08:00:58 am
I totally forgot to answer your question... In reverse there is a decent amount of slop. Not so much in the other gears (I think).
86 K20 4x4
7" lift, 35's
350/400/208
jaredts
May 27, 2011, 05:43:47 am »
Easiest and most likely culprit is still probably an adjustment of the neutral start switch. Have you tried that yet? Eliminating slop in the shifter may be something you have to tackle, but I doubt it and I really can't help much with that. The detents are in the transmission, so sloppy only in reverse may not be fixable anyway. This is an automatic right?
K20Wulf
Reply #12 on:
May 28, 2011, 05:32:16 am »
Yep, Th400. And sloppy in all gears, think it's in the column because the trans is perfect.
Last Edit: May 29, 2011, 12:12:44 am by K20Wulf
86 K20 4x4
7" lift, 35's
350/400/208
Steering Columns
