Author Topic: good cam choice for 350...  (Read 32247 times)
Offline derrick79
« on: May 22, 2011, 07:37:26 pm »
Just want everyones opinion on a good cam for my 350. Its in my 76 3/4 ton 4x4. I want something with good low end grunt but want to keep the engine virtually stock for now. It currently has a performer EPS intake with edelbrock 650 thunder avs carb, msd ignition and long tubes. The bottom end and heads are stock and I would like to keep it that way for now. A buddy suggested a comp cams xtreme energy xr268 with a set of valve springs. Any suggestions?
Re: good cam choice for 350...
« Reply #1 on: May 22, 2011, 08:31:28 pm »
Why don't you want to update the heads?
Offline derrick79
« Reply #2 on: May 23, 2011, 10:11:44 am »
Basically just to keep the cost down. One day I plan on doing the whole engine but for now I want a little more bang for my buck.
« Reply #3 on: May 23, 2011, 10:14:22 pm »
It's not really worth going with that cam and stock heads. It's like heavy breathing into a paper bag ya know?
Offline fitz
« Reply #4 on: May 23, 2011, 10:34:10 pm »
Been there, done that.
Offline 1980c10
« Reply #5 on: May 23, 2011, 11:59:58 pm »
Like vile says I would hold off until you are able to do the heads, shop around for a deal.
Offline TexasRed
« Reply #6 on: May 24, 2011, 04:57:26 pm »
how many miles on the engine, intended purpose, budget.
Offline 1979C20
  • Kyle Taulton.
« Reply #7 on: May 24, 2011, 05:17:03 pm »
If your using stock heads I would use a cam the complies with the limits of the stock valve train as well. I dont remember what model my cam is but its a comp cams and it was "the biggest cam I can get with stock valve train". Ill grab the receipt when I get home from work. Its got a great rhythm and throaty sound from the duration. My idle sits around 550-650 depending on temperature.
Offline derrick79
« Reply #8 on: May 24, 2011, 07:47:55 pm »
How many miles? I have no idea. The truck has almost 500 000kms on it. The engine isn't original it was dropped in with a fresh rebuild about 4 years ago. According to the guy I bought it off anyway. My intended use is more low end power with a noticeable idle. Not really sure on a budget until I do mote research.  C20 if you could find that cam that would be awesome! Thanks.
Offline 1979C20
  • Kyle Taulton.
« Reply #9 on: May 24, 2011, 07:59:10 pm »
I really like the cam. Make sure you buy cam and lifters because if you use a new cam with old lifters youll flatten it because of the different chemical properties. But i would definitely recommend it. I should be home in an hour or so and ill get the recipt. I think its a 460lift 240 duration, but I dont remember
Offline 1979C20
  • Kyle Taulton.
« Reply #10 on: May 25, 2011, 06:49:14 pm »
I posted this on the wrong page before so hefd it is now.
I found my cam in an old post of mine. http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=72&sb=0 I love it. It cost me 140 at my local lopers performancr shop.
Offline screamin86
« Reply #11 on: May 25, 2011, 07:53:01 pm »
I like my 214/224 .442/.465 112lsa cam I ran the same grind in the 305 I had in my 82 trans am. Summit sells a kit with it for like $90 cam and lifters part number is sum-1103. I ran the summit one in my car for 3 years and am running the eglin version in my truck.
86 ta:lm7 hot cam boltons
Offline derrick79
« Reply #12 on: May 25, 2011, 11:38:02 pm »
Thanks guys. I like the look of that kit c20 posted. I am really gonna have to think about this. If I had the time I would order it tomorrow. Ugh too many projects at one time.
« Reply #13 on: May 27, 2011, 03:30:52 pm »
This is the best bang for the buck and about as big as you can go with stock heads...
Offline NevadaNeal
« Reply #14 on: May 29, 2011, 05:40:36 pm »
Those two cam profiles are an intresting comparison of a single pattern and dual pattern camshaft's. Ive always believed that a nice dual pattern is the way to go. but ive met allot of folks who use a single pattern. I know the best way to wake up an old ford fe engine is use a dual pattern cam to help the exhaust scavenging. the fe heads have a poor exhaust runner design.
