Author Topic: Rear slider removal??  (Read 5446 times)
Offline Garrettsdad
« on: May 30, 2011, 01:12:13 pm »
What is the best way to remove a rear slider? Do you need special tools?   Thanks chris
Re: Rear slider removal??
« Reply #1 on: May 30, 2011, 02:20:44 pm »
It gets pushed out from the inside. Go easy and a little at a time. Fold the outer edge of the gasket so you can get it past the pinch weld.
Offline PromiseKeeper
« Reply #2 on: May 31, 2011, 09:06:24 pm »
I'd pull the gasket back a bit and lube things up with some spray window cleaner too. Just dont use anything petrolium based or you'll swell your rubber up.
« Reply #3 on: May 31, 2011, 09:10:21 pm »
If the rubber is rock hard and old your best bet is to buy a new seal and slice the old gasket, then push the window out. If the gasket is still in good shape, soapy water and a thin piece of roap or coated wire to work the assembly outward from the window frame.
Offline kevin53garcia
« Reply #4 on: June 02, 2011, 07:22:08 am »
I do exactly same......
But just aware of the petroleum part, so thanks for that!!!
