Author Topic: Front caliper staying applied 2 different trucks  (Read 6923 times)
Offline 313C10
« on: June 05, 2011, 05:41:41 pm »
just my luck this is happening on both my trucks at the same time the first is an 86 4x4 blazer the second is a 84 c10.The blazer is worse got a caliper for that, and putting it on now i dont really have experence with brakes exept air brakes. as for the c10 the rubber in the res. was getting sucked down i replaced that, still nothing it seems like if it sits for a while  it will push brake fluid through the resivoir and release. Any ideas im kind of lost and i cant farm it out. both have fluid and no kinks or leaks in lines.
1984 Chevy Custom Deluxe I-6 LWB
1986 Chevy Blazer 350 TBI. 8?+ in. Lift
Offline 1982 Daily Driver
Re: Front caliper staying applied 2 different trucks
« Reply #1 on: June 05, 2011, 09:22:10 pm »
Check the rubber lines going to the calipers, after time they deteriorate on the inside and work like a check valve not releasing the pressure after the brakes are released.
Offline 313C10
« Reply #2 on: June 06, 2011, 04:32:27 pm »
repalced the caliper on the blazer and it seems to be good now onto the c10
« Reply #3 on: June 06, 2011, 05:25:31 pm »
      Can you say "murphy's law"  Both rigs at the same time, same problem.  You are having a bad day my friend.
Offline 313C10
« Reply #4 on: June 15, 2011, 08:54:51 pm »
daily driver good call it was the brake line.replaced caliper also. any body ever replace the porportioning valve thinking about doing that for the heck of it
« Reply #5 on: June 15, 2011, 10:00:16 pm »
I'm glad I could help. I think a new proportioning valve is expensive for something to change for the heck of it. I have never herd of one going bad.
