Author Topic: Thinnest oil I can safely use in my TBI 5.5L?  (Read 8914 times)
Offline Skunksmash
« on: June 24, 2011, 03:51:24 pm »
I've been reading up on synthetic oil on Bobistheoilguy.co m. It seems that any full synthetic oil will slowly clean the inside of your engine. Some better than others however. The best full synthetic right now is Redline, which even eats varnish off. So I'm going to run that for a little while just to help clean up my old 5.7L TBI engine. Anyway, the thinner, the more quicker it can clean, apparently. So I was just wondering what the thinnest oil I can safely use in my 5.7L is. 5w20 perhaps?
Offline bigchevyc30
  • the pig
Re: Thinnest oil I can safely use in my TBI 5.5L?
« Reply #1 on: June 24, 2011, 09:57:29 pm »
idk if it works or not but my dad said when you change oil in a vehicle you bought or one you have and think needs to have the insides clean to fill it with diesel for where oil goes and run it for 10 min not to warm up the motor or anything just to get it running through as it will clean the oil glop out of the passages. im not sure if this work he says he did it back in the day and is going to have me do it on my 366 that we bought and he says not to put the new filter on till u have emtied out the diesel
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
« Reply #2 on: June 24, 2011, 10:02:32 pm »
My dad used to do it about once a year in his work car.  Never had an issue.
Offline topp
« Reply #3 on: June 24, 2011, 10:48:20 pm »
You can also add 1 qrt of tranny fluid, run for 10 minutes, then drain and replace oil and filter....
You can add Seafoam to the oil, and then run it for a while, then drain and replace oil and filter....
'90 Suburban TBI 350
Offline bigchevyc30
  • the pig
« Reply #4 on: June 24, 2011, 11:48:21 pm »
though for me im going with diesel he told me to put 2 gallons in since i have a 10qt oil capacity
Offline Skunksmash
« Reply #5 on: June 25, 2011, 12:13:35 pm »
I know about all those methods but I prefer to use a slow and steady method, rather than all at once. So does anyone know what the thinnest oil I can safely use is?
Offline topp
« Reply #6 on: June 25, 2011, 12:52:27 pm »
"thinest" is defined by your location and climate, How often you run your truck, what conditions you run it under and many other factors....
Offline Skunksmash
« Reply #7 on: June 25, 2011, 09:11:36 pm »
The punishing Texas heat is my climate. I don't drive the truck daily. I probly only a couple days a week. As for conditions I run it under, I pretty much baby the truck. I don't rag on it at all cause its just an old truck. No point in raggin' on something that was never meant to be fast lol.
Offline bigchevyc30
  • the pig
« Reply #8 on: June 25, 2011, 09:39:45 pm »
i agree with you on the trucks not built to go fast since i put in the new motor in my truck its only seen the interstate 1 and it was only a 3 miles on that. my old motor went out cause i always went on the interstate when i head into town. but like you now i dont hotrod and things like that since it still dont have any good fuel mileage
Offline Skunksmash
« Reply #9 on: June 26, 2011, 05:06:34 pm »
Guess I'll just try 5w30
Offline nativetexan
« Reply #10 on: June 26, 2011, 09:18:07 pm »
If you don't drive it that often, and if its an older engine, I wouldn't worry about thinning out your oil. Just run what you have been running to keep your seals tight.
Offline slammed79
  • Thou shalt not drive stock
« Reply #11 on: June 27, 2011, 10:53:29 pm »
Also, if you switch to full synthetic it is a pita to go back. As I understand it, you need to do an engine flush before switching back to conventional.
Just heresay really, but someone might have more info on this.
Praise the lowered
