Author Topic: quad headlight conversion  (Read 10922 times)
Offline 4x4x4x
  • 85k10 diesel
« on: June 27, 2011, 01:46:17 pm »
for anyone wanting to convert their quad headlights to h4, h1 bulb system, here is a very reasonable source for hella replacement headlights.
http://www.ronthebusnut.com/browseDisp.php?search=&advSearch=&ID=49&order=&lim=20
the hella's are high quality euro lights that are much brighter that the stock headlights. because they have a beam cut off pattern, when properly aimed they do not blind on comming drivers.
alec
85 k10 swb, 6.5 diesel. banks sidewinder turbo, 700r4, auburn gear ected limited slip/lockers f & r, 411 gears, front slotted disks, rear disk brakes, 4"exhaust,  cibie headlight and fog lights, rancho rear spring lift, rancho shocks, new ft. springs,
Offline Edahall
Re: quad headlight conversion
« Reply #1 on: June 27, 2011, 08:13:49 pm »
Wow, I wish they were this price for the the quad headlights on my 1990 Suburban which has a front end like the picture.  I had to pay $180 for a pair of Hella headlights that would fit but it made a huge difference.
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Offline 4x4x4x
  • 85k10 diesel
« Reply #2 on: June 28, 2011, 09:32:24 am »
the hella's offered for sale are the 165mm that fit 85 through 87 full size chevy trucks.  the quads on the 88 and up are a different size. hope this helps
Offline ehjorten
« Reply #3 on: June 28, 2011, 01:41:52 pm »
Yeah...those are 100 x 165 mm rectangular lamps and for the chevy quads you need the 92 x 150 mm lamps.  No one makes a good set of conversion lamps for these anymore.
-Erik-
Offline Edahall
« Reply #4 on: June 28, 2011, 01:58:13 pm »
I bought a set of 92 x 150 mm Hella lamps less than a year ago however, they were very expensive.
-3.73 gears
-2" Lift
Offline jaredts
« Reply #5 on: June 28, 2011, 04:37:14 pm »
81 thru 84?
« Reply #6 on: June 28, 2011, 09:00:57 pm »
I just swapped my bike over to 7" round Hella head light. $48 for everything.
