Author Topic: Swap 10 bolt to 12 bolt rearend  (Read 55209 times)
Offline daman02
« on: July 02, 2011, 08:39:06 am »
Well i'm jumpin back into my '86 2wd chevy and going to do a few things to it soon.  It has the factory 10 bolt rearend right now that i put 3.42 gears in about 5 years ago but i have a 12 bolt rearend out of a '78 big 10 i think it was that i'm wanting to put in it(both r 5x5).  I'm running a 700r4 tranny with 2500 stall but since this truck is just a cruise around and occasional dragstrip truck i'm wanting to go with 4.10 gears and possibly 3.73 to really give it some bottom end.  The tires I'm running are 295/45 18 which are 28.5" tall.  My main question is are the 2 rearends the same dimensions as far as total width and does it have the same mounts as the 10 bolt and are there any other things I would have to change to drop it in?  Also give me your opinions on which gears you think I should go with. I only ask all this because I am currently out of state but am trying to get a plan together to do it when i get back for fall.  Below is what it looks like now.
http://www.cardomain.com/ride/771450/1986-chevrolet-silverado-1500-regular-cab
'86 C10 Silverado 350 with 700r4 and 2500 stall
Dropped 2" in front and 2" in rear but soon to b 4" in rear
18x10 wheels with 295/45 18 tires
Re: Swap 10 bolt to 12 bolt rearend
« Reply #1 on: July 02, 2011, 08:45:03 am »
5x5? but the rears will swap if the 12 bolt came out of a truck. what ratio is in the 12 bolt now?
« Reply #2 on: July 02, 2011, 08:51:35 am »
Only physical difference is the u-joint between the 10 and 12 bolt
Offline daman02
« Reply #3 on: July 02, 2011, 08:52:47 am »
they are both the 5x5 bolt pattern.  the 12 bolt has 3.42 gears also.  Good to know that it will drop right it though.
Offline daman02
« Reply #4 on: July 02, 2011, 08:54:48 am »
Good info there.  thanks
Offline three8six
« Reply #5 on: July 02, 2011, 10:52:49 am »
Can I ask why this is desirable? a 12 bolt is stronger than a 10 bolt? or are you having problems with your rear end?
Offline daman02
« Reply #6 on: July 02, 2011, 11:43:31 am »
yea the 12 bolts are stronger and have more splines on the axles as well.  Plus it I already have one and I'm planning on a pretty high hp engine in the next few years
Offline three8six
« Reply #7 on: July 03, 2011, 05:28:39 pm »
I was just curious. Please post details. I have 10 bolt in my truck and I got a good 12 bolt just hanging out in the shop on an identical frame. I thought the ring gear was only like 8 7/8's?
« Reply #8 on: July 03, 2011, 11:01:32 pm »
if they are stronger i dont think its that much stronger 10 bolt ring gear is 8 1/2 and the 12 bolt is 8 7/8 but the 10s where only 1/2 ton and the 12s where 3/4
« Reply #9 on: July 04, 2011, 07:20:46 am »
I have never in all my years working on and playing with these trucks seen a 12 bolt in a 3/4 ton! Only rear offered in 3/4 ton was a 14 bolt full floater, and a 14 bolt semi floater.
12 bolts are not that much stronger than a 10 bolt. You will need a crossover u joint, The cross width is shorter on a 12 bolt, and the cap diameter is smaller on a 12 bolt.
All Chevy 1/2 ton 2 wheel drives are the same lug pattern.
Offline chevymanrob
« Reply #10 on: July 04, 2011, 10:21:22 am »
the way i understand it is that the truck stuff is VERY similar in durability between 10 and 12 bolt stuff. the car stuff is where the difference is noticable. i know the A body 12 bolt i had was awesome. and if it were my pennies i would just work with what i have. you can build a really strong 8.5" for not alot of $.
ex G-body drag fan. best was 11.86 on a 93 octane SBC street car.
Offline daman02
« Reply #11 on: July 04, 2011, 01:10:39 pm »
I always read that the 12 bolts were stronger but i never thought about them refering to the 10 bolt car which is 7.5" i think.  I might just leave the 10 bolt in and work with that like you suggested.  This is why forums are so great.  I was about ready to order gears, mini spool, and bearing kit for the 12 bolt when I already have all that for the 10 bolt.
Offline chevymanrob
« Reply #12 on: July 04, 2011, 01:33:43 pm »
there are guys with the 8.5" Gbody rears (grand national and 442s) WELL into single digit 1/4 times....thats 500+ horsepower. i am only going to run the 10 bolt in my truck.
Offline three8six
« Reply #13 on: July 04, 2011, 05:39:11 pm »
10 bolts in F/S trucks are 8.5inch
« Reply #14 on: July 04, 2011, 11:07:39 pm »
see blaze thats what i thought also but then i went on
http://coloradok5.com/axleguide.shtml
and i thought they have there stuff inline and knew more than me lol
