Author Topic: 85k20 kick down ??  (Read 3548 times)
Offline tigwelder
85k20 kick down ??
« on: August 10, 2011, 06:52:17 am »
where does power come from for the kick down switch on 85 k20 with 400 turbo? switch is under dash near gas pedal.is this fused?
Re: 85k20 kick down ??
« Reply #1 on: August 10, 2011, 10:09:17 am »
¿Qué? ???its just a cable from the carb to the trans aint it?
Offline Grim 82
« Reply #2 on: August 10, 2011, 01:47:48 pm »
Any switched 12V will work, not sure if they were originally fused though.
Offline Psycho71
« Reply #3 on: August 11, 2011, 10:45:27 pm »
Not sure where it comes from on mine, never looked. I would think any switched wire would work just fine, and it certainly wouldn't hurt to have it fused. At worst, the fuse blows and it won't kick down? Crazier things have happened.
And Irish, the TH400 uses an electric kickdown under the dash, as opposed to the th350 which is cable operated at the carb.
