Author Topic: q jet question  (Read 4744 times)
Offline str8bloc
  • MISTRESS
q jet question
« on: August 21, 2011, 08:16:32 pm »
i got a complete rebuild qjet for a set of rallies. it came fm an 80 4x4 454 will it work on my 305 or what
FaTbOy
Re: q jet question
« Reply #1 on: August 22, 2011, 09:03:26 pm »
yes
Offline str8bloc
  • MISTRESS
Re: q jet question
« Reply #2 on: August 24, 2011, 05:21:18 am »
so just gotta tune it sweet . goes on thursday
FaTbOy
Offline jaredts
Re: q jet question
« Reply #3 on: September 12, 2011, 04:21:44 am »
It'll work, but the jets, metering rods, spring hangers, just about everything will be a far cry from the quadrajet GM would have put on your 305.  Air/fuel ratio won't be perfect, but might be o.k. with a little tuning.  All that stuff can be changed out anyway.
Offline lukieg
Re: q jet question
« Reply #4 on: September 13, 2011, 10:37:37 pm »
 I put a 305 qjet on a 366 tall deck once... worked beautifully! 5.0 to 6.0 with absolutly nothing done to it aside from adjusting the secondary av.
 Granted a 454 is a fair bit larger.. but depending on the build and the expected rpm you may get away with minimal adjustments...rejetting and so on. Personally I would have already slapped it on and tried... why not?
« Last Edit: September 13, 2011, 10:39:59 pm by lukieg »
