Author Topic: vent window problem  (Read 8864 times)
Offline bigchevyc30
  • the pig
vent window problem
« on: August 25, 2011, 01:46:49 pm »
ok the vent window on my driver side is not held in by the frame when i open it how would i fix this as it helps with flow of air since my truck has no ac. i need it fixed cause if i dont i think the whole piece of glass will fall out when going down the road. thanks for the help in advance if you can help me
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
Online zieg85
Re: vent window problem
« Reply #1 on: August 25, 2011, 02:06:43 pm »
I usually go to the local pick and pull and get one out of a door.  Non-AC trucks have the best ventilation IMO because of the vents down low.
Offline bigchevyc30
  • the pig
« Reply #2 on: August 25, 2011, 02:09:01 pm »
well this trck came with ac but the p.o. removed everything in it so it has no more ac
« Reply #3 on: August 25, 2011, 02:13:02 pm »
As in the glue is not holding it in anymore?
Offline bigchevyc30
  • the pig
« Reply #4 on: August 25, 2011, 02:49:11 pm »
the sheet of glass came out of the frame that pivots. is what im talking about
Online zieg85
« Reply #5 on: August 25, 2011, 03:01:44 pm »
I have had luck with clear silicone to put them back in, I thought you were referring to the rivets being bad or rusted out at the pivot point.
Offline bigchevyc30
  • the pig
« Reply #6 on: August 25, 2011, 03:02:59 pm »
so i can just get silicone or some sort of adhesive to put my window back in if it come out completely
Offline jaredts
« Reply #7 on: August 25, 2011, 04:41:37 pm »
Urethane windshield adhesive from a body supply store is awesome stuff for this kind of thing.
Online zieg85
« Reply #8 on: August 25, 2011, 05:05:26 pm »
If that is the case I bet it wouldn't cost you much if you swung by a glass shop and asked them for a bead of adhesive.  I know it is a moisture cure type and it may not be available in small quantities, but I haven't checked...  A normal size tube would go bad within a month if you just needed a little.  My $.02
Offline PromiseKeeper
« Reply #9 on: August 26, 2011, 07:50:29 am »
BigChevy,
I had the same problem. The channel that the glass goes in is wide enough that just putting a sealant in it will not allow you to align the glass easily (This is assuming you have cleaned out the old gasket out of the channel, which is probably what caused the problem). There is a gasket like material that goes in that channel. Most likely yours has dried up, cracked, and maybe even partially fallen out. Stop by a glass shop and ask them if you can buy enough to reset it. It comes on a roll and in different thicknesses so take the truck along to get the right one. You can reset it from there and trim it with a razor when you're done. You'll have to notch the corner to make it fit right. It's not a hard job. I used urethane on mine as well to get it to seal. My local shop didn't really want the job because so many trucks from Ohio have rusted vent frames so they were glad to just give me the materials.  ;D
Scott
« Last Edit: August 26, 2011, 08:01:03 am by PromiseKeeper »
