Author Topic: Cab Mounting Question  (Read 3511 times)
Offline sonicbluezx3
« on: September 12, 2011, 02:51:58 pm »
I have a 1983 cab that is going onto a 1986 frame. I need to buy replacement cab mount assemblies (not just the bushings)....   There is a kit for a 1981 to 1983, and another kit for a 1984-1987. I looked at the teardown for both kits and everything is the same except for the lower cushions on both the front and rear mounts. Anyone know which kit I should be getting? I assume it goes by frame year since that lower cushion is below the frame mount.... but I want to make sure before spending that much and getting the wrong part.
Thanks.
« Last Edit: September 12, 2011, 05:24:43 pm by Captkaos »
1986 Chevy K10 w/ 1983 Cab, 1984 Bed, 1987 Doors and a 6.2 Diesel Swap w/ 700R4 Trans. Truck body completely re-done between 2010 and 2012.
Re: Cab Mounting Question
« Reply #1 on: September 12, 2011, 05:24:59 pm »
Order bushings for the frame year.
