Website/Forum News and Info
1973-1987(91) Analog Gauges
Topic: 1973-1987(91) Analog Gauges (Read 52054 times)
October 19, 2011, 01:48:29 pm »
Here is the link to pre-order the
73-87 Analog Gauges
. They are listed for $775 (special pricing for store members)
These are the pictures of the new Analog gauges (Carbon Fiber and Blue Pictured -
bezel NOT included
) Red is the other option for font color along with Silver Alloy background.
NOTE:
they are
PRE-ORDER
only right now and it will take at minumum 4-5 weeks
BEFORE
they are completed and shipped.
NOTE: To recieve special pricing on these you HAVE to have an account in the store. If you don't see special pricing and you have created an account/login, EMAIL me.
These new systems along with the Digital systems allow you to purchase additional modules to display more information in the message center. Optional models are: OBDII Interface, Pressure Module, Temperature Module, Voltage/ Current Module, EGT, Head Temperature Module, Air Temperature Module, Clock Module, Compass w/ Outside Temperature Module and Quad Air Pressure Module
bake74
Re: 1973-1987(91) Analog Gauges
October 19, 2011, 06:24:49 pm »
Hey capt. is there a close up shot of the whole cluster ? Does it have a tach included. ( us old guys can't see that well anymore )
74 k10, 77k10 Tom
1979C20
Kyle Taulton.
October 19, 2011, 08:42:55 pm »
Does it come.with everthing to control the gauges? How does it work with a cable speedo?
October 19, 2011, 08:44:45 pm »
by the looks of it they seem to have the layout of the digital ones tach on the right
October 20, 2011, 04:57:56 pm »
The kit comes with everything, the speedo is electric not cable.
Water, Fuel, Oil and Volts on the small ones, Speed and Tach for the larger ones.
bigchevyc30
the pig
October 20, 2011, 05:21:01 pm »
this is pretty cool i guess it replaces the circuit paper guages
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
October 20, 2011, 06:20:44 pm »
its mounted in its own cluster. almost as if someone gutted one of our gauges and inserted new gauges. you just have to put the bezel on and its just like oem except for the computer box with a bunch of wires running to it. i would imagine it is kind of similar to the digital setup
http://forum.73-87chevytrucks.com/smforum/index.php/topic,7638.0.html
October 20, 2011, 07:09:04 pm »
It is just like the digital version in how it replaces the factory cluster. Just remove the factory one and put this in, wire it and your done.
bigchevyc30
the pig
October 20, 2011, 09:01:29 pm »
man now i really need to be saving my money my dually would look even better inside with these and i could actually see what the rpms of my motor are. this looks great capt keep it up with the great finds
1979C20
Kyle Taulton.
October 20, 2011, 09:16:13 pm »
What I meant by my speedo question, is, what would I need to do to make it work with my truck, which has the cable speedo?
October 20, 2011, 10:50:32 pm »
no it has a electric sending unit you thread into your transmission where the speedo cable goes, then you have to either drive 1 mile or know a set speed and set it to that. That’s the main reason I got the digital ones is for my bigger tires
1979C20
Kyle Taulton.
October 21, 2011, 10:18:48 am »
Oh, well thats cool. It comes with the all electric sending units?
Reply #12 on:
October 21, 2011, 10:39:57 am »
if i can remember right it has an adapter to fit your trans. then it also has a pin like whats in the speedo cable. i had to cut it down to make it fit then i didnt cut it down enough and it separated the sending unit so i had to pop everything back in place and put silicone on the edges so no water could get in. that was the only problem i had with mine
Reply #13 on:
October 21, 2011, 11:43:11 am »
It comes with everything.
bake74
Reply #14 on:
October 21, 2011, 01:33:05 pm »
These are pre-order units now, capt. are you planning on stocking these in the future, or will they always be pre-order ? ( I want one, but wont be ready till next summer for gages)
74 k10, 77k10 Tom
