Author Topic: Extended tip or no?  (Read 3110 times)
Offline boyer61
Extended tip or no?
« on: November 06, 2011, 10:52:51 pm »
It's calling for R44ts for light duty, r44t for heavy duty.
On the TS, the tip is more extended, the T it's must more recessed into the plug.
Which one should i use?
Motor is a 77 305 bored out .30 over, slightly mild cam, and headers.
Offline 1980c10
Re: Extended tip or no?
« Reply #1 on: November 06, 2011, 11:20:48 pm »
I will always go with what is recommended with the heads I am using. The safer bet would be the r44t as it would give you more clearance on your pistons you don't want to get too close and create a "hot spot". If, however, you have been using the r44ts I would stick with them. I am not speaking from experience on this, just what crosses my mind.
Offline boyer61
« Reply #2 on: November 06, 2011, 11:27:10 pm »
Im currently using r43ts, one stage colder than the 44's.
The heavy duty and light duty threw me off lol
