Author Topic: slip yoke  (Read 12781 times)
Offline necromonger
slip yoke
« on: December 06, 2011, 03:52:17 pm »
Hello,This is Greg again i was replacing the u joints and the slip yoke is shot someone drove it with a bad u joint.It is a 15 spline yoke and i need to find one.This is on my 78 K30
new build,1978 chevy 3/4 ton 2 wheel drive 350 4 speed trans.
Re: slip yoke
« Reply #1 on: December 07, 2011, 07:21:10 am »
     What transfer case do you have ?  I looked and all I could find for a 78 k30 are 32 spline yolks, I tried 203, 205, and 208 transfer cases, do you have something different ?
Offline necromonger
Re: slip yoke
« Reply #2 on: December 07, 2011, 08:06:59 am »
I have a np205 case. This is the yoke on the front of the rear drive shaft that slides onto the Carrier bearing shaft.
Re: slip yoke
« Reply #3 on: December 07, 2011, 09:55:45 am »
     http://www2.dana.com/pdf/J300-P3.pdf
   Check out this website, starting on page j300p-3, they start with the 15 spline yolks.  They have cross reference numbers so that you can either call spicer (phone number on last page), or maybe take this number to your local parts house.
   Also they say there is multiple applications and show you how to measure your yolk to get the right one.  Good luck and keep us informed on what you find.
Re: slip yoke
« Reply #4 on: December 07, 2011, 03:00:08 pm »
whats wrong with your old one? how much damage?
Offline necromonger
Re: slip yoke
« Reply #5 on: December 07, 2011, 06:53:33 pm »
A bad u joint trashed the yoke.
Re: slip yoke
« Reply #6 on: December 07, 2011, 06:59:41 pm »
i know its not safe to some but we have run yokes with a ear cracked off before on a mud truck turning 44's to this day no issues
Offline necromonger
Re: slip yoke
« Reply #7 on: December 07, 2011, 07:11:42 pm »
I will be hauling 3 to 4 tons of house coal on this truck.It is so bad you can almost install the u joint with your fingers.
Offline necromonger
Re: slip yoke
« Reply #8 on: December 08, 2011, 01:07:25 pm »
I found it here http://www.northerndrivetrain.com/category/cat_driveshaftcomp_slipyokes_1-965-29-30spline.html
here is the part number SPI-3-3-5921KX
        Thank's for the help
Re: slip yoke
« Reply #9 on: December 11, 2011, 03:10:27 am »
i think a junkyard would be a much better deal or at least worth a try
Re: slip yoke
« Reply #10 on: December 11, 2011, 08:19:22 am »
     That one says it is a 29 spline, I thought you needed 15 spline ?
Offline necromonger
Re: slip yoke
« Reply #11 on: December 13, 2011, 04:15:44 pm »
I messed up and posted the wrong link.Here is the the one.http://www.northerndrivetrain.com/product/SPI-3-3-5921KX.html
No junk yard any where had one that i could find.
Re: slip yoke
« Reply #12 on: December 13, 2011, 07:47:36 pm »
     That is kinda pricey, but if you can not find one elsewhere, I guess it is not bad to be able to drive your truck again.
Re: slip yoke
« Reply #13 on: December 13, 2011, 09:11:49 pm »
he can still drive it with just the front shaft 8)
Re: slip yoke
« Reply #14 on: December 13, 2011, 09:20:52 pm »
or you could just put a one peice shaft in its place
