Author Topic: hesitation between 1700 and 1900 rpm  (Read 3428 times)
Offline the_legend_1981
« on: December 18, 2011, 11:14:38 am »
tbi. I really only feel it in overdrive going up a little bit of a grade. It cuts out and then goes back to normal. Any ideas? I'm wondering if my timing could be off
« Last Edit: December 18, 2011, 11:24:58 am by the_legend_1981 »
Re: hesitation between 1700 and 1900 rpm
« Reply #1 on: December 24, 2011, 01:51:48 pm »
Did you find your answer to this?
« Reply #2 on: January 03, 2012, 10:38:15 pm »
Not yet. It's more between 1500-2000. Maybe objectors are dirty?
« Reply #3 on: January 03, 2012, 10:58:25 pm »
Also idles rough in winter months. Could it be related?
« Reply #4 on: January 03, 2012, 11:01:27 pm »
Check your vacuum lines for cracks.  Your temp sensor could be off some not giving the proper air/fuel mixture.  My $.02
« Reply #5 on: January 03, 2012, 11:19:03 pm »
^ This, and...
1) Check your fuel filter.
2) If you have a pressure gauge with the correct adaptors, have someone ride with you and monitor your fuel pressure while driving.  Be really careful if you do this - gas in the cab or any fuel leak for that matter can be deadly!
3) Inspect your spark plugs, cap & rotor.
4) When you pull the plug wires off look into the ends of the wires for black soot or green discoloration.
5) A sticking EGR valve can also mimic your symptoms, as well as other things.
