Author Topic: Trans modulator adjustment?  (Read 3152 times)
Offline MyOldScottsdale23
« on: February 13, 2012, 08:16:06 am »
I just bought a 1985 GMC SierraClassic 4x4. SWB Fleet. It has a 350/TH400 the Kickdown solenoid wasn't plugged up so I got that working. It still seems to upshift too soon. I have seen a few mentions on other posts about adjusting the modulator. Which direction and how much would I need to turn it to make it shift at higher RPM
Re: Trans modulator adjustment?
« Reply #1 on: February 22, 2012, 11:40:07 pm »
part throttle or WOT?  WOT is controlled by the governor weights on a TH400.
« Reply #2 on: February 27, 2012, 01:04:02 am »
Both
Offline ehjorten
« Reply #3 on: February 27, 2012, 09:34:40 am »
You need an adjustable vacuum modulator to adjust part-throttle shifts.  The adjustment is done with a small flat-blade screwdriver.  You take off the vacuum hose and inside the modulator vacuum connection is the adjustment.
You need a governor recalibration kit to adjust the WOT shift points.  Obviously, adjusting this will affect the part-throttle shift points as well, but the vacuum modulator gives you full control over both.
-Erik-
« Reply #4 on: March 03, 2012, 08:00:06 am »
Thank you
