Author Topic: 3/4 ton control arm assembly  (Read 4209 times)
Offline seventyx3
« on: February 19, 2012, 09:12:31 pm »
Can a 3/4 ton lower control arm assembly be used in place of a 1/2 ton?  The spindle would remain 1/2 ton.  The 3/4 ton lowers are less expensive.  Are the bushings easier to replace on the 3/4 ton lower control arm shaft? All 2wd drive trucks.  My 1/2 ton bushings need to be pressed in by a machine shop and the nearest established shop is 80 miles away.
Re: 3/4 ton control arm assembly
« Reply #1 on: February 22, 2012, 05:03:10 pm »
I honestly can't remember this for sure, but I think the balljoint won't work...
