Author Topic: gm corpo 14 bolt rearend to front end swap  (Read 13958 times)
Offline mini_etr77
  • Grease Monkey
« on: February 23, 2012, 10:29:13 pm »
I pulled a 14 bolt gm rear end out of a dually a 77 dually I had(rust bucket). I waas wondering how I could go about getting it fliped or whatever to run it in the front, 77 chevy stepside 4x4 I already have the same one in the back iits the 10.5 inch ring gear
77 chevy scottsdale stepside,lifted 6" on 35 swampers with a hot rod 350 daily driver
78 chevy longbed fleetside part rig
89 chevy silverado undergoing engine swap(350 to 468) and a little beefing up
Offline Da67goatman
  • Burban
<Pitcrew>
Offline mini_etr77
  • Grease Monkey
Re: gm corpo 14 bolt rearend to front end swap
« Reply #2 on: February 23, 2012, 11:35:26 pm »
Much obliged
Offline frotosride
    • WFO CONCEPTS
« Reply #3 on: February 24, 2012, 07:48:52 pm »
I have watched this over and over again and have it on my DVR so if you decide to do it post pics of each stage and let us know what it realy took to do it. I mean i don't think he is lying but seeing it done with out the magic of TV would be nice.
Offline Da67goatman
  • Burban
« Reply #4 on: February 24, 2012, 11:27:13 pm »
What vehicle are you wanting to put it in?  You might have issues offsetting the diff and finding axle tube and shafts long enough to put it under a full size rig.  They cut it down to fit a jeep so they just cut one side to offset and narrow.
<Pitcrew>
Offline Psycho71
« Reply #5 on: February 26, 2012, 09:48:40 pm »
Great point on the wheel track. Definitely something to look at before diving into. I have yet to watch those shows, but have them DVR'd.
Offline aaronwilliams
« Reply #6 on: February 26, 2012, 11:21:56 pm »
wow sweet shows!!!  They do breeze over diff alignment for the front install though. I mean i know its not a rocket ship but its important to explain how they measured the outputs on the np 205 to determine axle tube length. Also excellent point that you may be need to lengthen one shaft depending on application.
definitley makes me want to do a disc conversion. wonder if its that easy on a dual wheel setup, im gonna take some measurements this week and i'll reply with any more insight.
Running: 1988 Chevy V30 Custom Deluxe C&C dually 454 4bbl, 1995 GMC K2500 Suburban 454 TBI
Projects: 1968 C10 stepside 350 TH400, 1987 Chevy V30(rusty c&c) dually 454 TBI
« Reply #7 on: February 27, 2012, 12:56:13 pm »
Ok, i started measuring and got confused pretty quickly. Turns out the c&c drw 14b is the shortest at 63.5 followed by the srw @67.5. The longest was the drw pickup(non c&c)@  72".
This gives excellent description for id your 14b.
http://www.pirate4x4.com/tech/billavista/14b_bible/
Offline mini_etr77
  • Grease Monkey
« Reply #8 on: February 27, 2012, 09:30:52 pm »
I'm putting it in my 77 stepside, once I can afford it.
« Reply #9 on: February 28, 2012, 12:00:08 am »
If you have the np 205 its ~9.5" center/center between front and rear outputs. This will be offset from center for the 14b pinion location.
I would use your existing front axle (d44 or 60?) as a guide for the overall length(steering knuckle - steering knuckle) and spring perch location. Find the 14b front steer kit online and get knuckle dimensions. Using that as a reference point to determine how much to trim from the pass side and if the drv side is long enough.
http://shop.cranehiclearance.com/product.sc?productId=56&categoryId=1
(this one even comes w/ custom seal kits but its too expensive for me)
Offline Da67goatman
  • Burban
« Reply #10 on: February 28, 2012, 08:42:42 am »
don't forget 14bolt ff has offset pinion to begin with, might not be in the direction you need, but it still has to be calculated for.
<Pitcrew>
Offline Engineer
« Reply #11 on: February 28, 2012, 07:18:15 pm »
Custom Differentials in Bloomsdale, MO has done a ton of one-off custom front axle builds.
Give them a call, they should be able to help.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline fitz
« Reply #12 on: February 29, 2012, 11:31:43 am »
I think a Dana 60 would be cheaper to do.
Offline snibook7537
  • Vince Ziolkowski
« Reply #13 on: March 06, 2012, 12:09:50 pm »
I'm with fitz on this one to. I don't really want to bash what you'r doing because if I had the cash it would be a really neat thing but whats the advantage of this? I get it that the 14bolt is stronger but are you really going to need the thing? It's like putting a 14 bolt rear end in a chevette with the isuzu diesel, just seems like overkill. If you do end up doing it though let us know as it's wicked cool looking from the videos.
1984 Fiero se pwr windows Holley TBi, cam, 86 5spd
1987 GMC V3500 350 TBi 4spd 205 t-case
Shoulda never sold:
1976 c-10 beater 250-6 4spd no pwr steering, brakes. Recycling truck
