Author Topic: Truck is leaning to one side ???  (Read 36282 times)
Offline 1987V204X4
« on: April 04, 2012, 01:41:42 pm »
Ok here goes..... I just bought this truck a week ago, it is a 99% rust free 87 V20 4x4 6.2 Diesel with 81,500 original miles. It needs alot of little TLC. I will start with the Suspension It had a 3" lift and the truck leans/ sags to one side, "driver side" It looks like everything is good but I'm not for sure???? Could it be the shocks??? If so why would both the front and back be leaning 1" compared to the right side???
My next question is how difficult would it be to remove the 3" lift kit and put it back to the stock hieght??? What all is involved with the swap??
My tires are 315-75-16. From the ground to the bottom of wheel well the driver side is 41 1/4"  passenger side is 42 1/4" that is from both the front and back wheel well.
What is the biggest 16" tire that will fit under a stock hiegth 87 3/4ton 4X4 ???? I will be putting on a Boss snow plow befor next fall, so I'd really like to bring it back down if I could.
The truck needs alot more, but I will post that in other threads.
Offline Da67goatman
  • Burban
Re: Truck is leaning to one side ???
« Reply #1 on: April 04, 2012, 02:23:26 pm »
I had a similar problem with a jeep I lifted, it had one broken leaf in the rear and the whole truck leaned to that side, Check the spring packs for breaks or cracks.
<Pitcrew>
Offline firefighter
« Reply #2 on: April 04, 2012, 03:55:01 pm »
Shocks don't normally have anything to do with ride height unless they are coil spring assisted shocks.
Ride height and the state of being level are controlled by the leaf springs, shackles, bushings, tire pressure etc...
If it's a suspension lift, there is normally spacer blocks on the rear leafs that you can remove but a true lift kit has special leaf springs in the front. You'd need a set of stock front leaf springs.
For lifts above 2" some installers add a modified steering arm to keep the steering geometry correct. You may have to go back to a stock one of these if the original installer added this.
You may also have extender brackets on the front sway bar if you have one.
Installing or removing a lift kit just takes time. It's pretty simple mechanics but can be a bit time consuming.
Good luck !!
« Reply #3 on: April 04, 2012, 06:31:28 pm »
     This is a really loaded question.  In short, you can get a thousand possibility's, what you need to do is look at all the suspension parts, I mean all of them, and compare between the left and right side.
     Make sure to look at the frame left to right, make sure the tires are the same (aired and size, though you probably have), the thing you are looking for is a difference between the left and right side that could have a 1" difference.  Don't forget the simple things like measuring the leaf springs shackles to make sure they are the same length, like I said it could be thousands of different answer's.
     Do a very through look over and report back your findings.
     As far as returning to stock height, as firefighter stated, depends on how they lifted it and weather it was done correctly or someone hacked it up lifting it.
     Post pics of what you find if you have problems identifying anything.
Offline 1987V204X4
« Reply #4 on: April 04, 2012, 06:57:42 pm »
Ok thanks guys I will look into this a bit more.
Tomorrow I'm getting a new set of wheels, while it's up on the lift I will try and get a good look. Oh and I'm going to just keep the same suspension lift that on the truck. I might go to a smaller tire later down the road after I ware these down.
Offline codyC10kid
« Reply #5 on: April 18, 2012, 11:39:45 pm »
i know my brothers 82 c10 305ci 2wd leans on the drivers side but thats just the heavy gas tank and drivers always leaning to that one side
Offline velojym
« Reply #6 on: April 19, 2012, 12:26:33 am »
Weightwatchers? ;)
« Reply #7 on: April 19, 2012, 10:58:00 am »
1" difference on a 4x4 isn't that huge.  No vehicle is going to sit level due to the characteristics of the steel in either spring.  To remove the lift, find out how it was lifted and removed everything and put stock replacement pieces back in.
Offline Avidyn
« Reply #8 on: April 19, 2012, 11:57:24 am »
I've had similiar problems with older lifted Toyotas. Not sure if Chevy did the same thing in the 80's as them. But, Toyota used to actually put a heavier spring pack on the drivers side. This was due to driver and fuel tank weight. They tried to keep it from getting saggy with time.
« Reply #9 on: April 19, 2012, 07:29:34 pm »
     You could always raise the low side 1" and call it good.
Offline 1987V204X4
« Reply #10 on: April 19, 2012, 08:10:14 pm »
The driver side is 1.75" lower than the passanger side. Last time I checked it was only 1" ?????? It is very noticeable, and it's driving me nut's everytime I walk out to look at it!!!!
Offline tpull123
« Reply #11 on: April 24, 2012, 01:36:55 pm »
Mine is doing the exact same thing in the left front (drivers side), and yes it looks really bad.   I suspect that the repeated abuse of the steering motion (back and forth) in the same direction of the leaf spring causing it to flex each time you turn the wheel has worn the spring out causing it to sag.   Mine has the cummins that weighs a few hundred pounds more which makes it even worse.    I plan to go to the cross over steering soon to improve the steering, and potentially put new springs in the front.    Check for any broken leafs as mentioned before.
1978 Frame w/ Cummins Diesel, 85 cab and front end, and time well wasted....lots of it!
Offline Jesse Walter
« Reply #12 on: April 27, 2012, 08:33:03 pm »
It may just be worn out cab mounts.
Jesse Walter
86 K20 4x4
86 C30 Dump
« Reply #13 on: April 28, 2012, 02:42:12 am »
mine is sagging on the right side. and it did it with the old springs that where broke, and the new springs
Offline tpull123
« Reply #14 on: April 28, 2012, 07:26:24 am »
THats a Head scratcher......   all you can do is get in on a level surface, and break out the tape measure and start measuring all kinds of supsension points comparing left and right sides.
