Author Topic: why does my truck run the way it does?  (Read 18131 times)
Offline rusty but trusty
« on: April 11, 2012, 02:38:09 pm »
OK my truck is a 1987 GM v1500 that had a tbi 350 but the guy i bought it from said he put in a 305 and to the best of my knowledge it is a 305. but the problem is it starts awful i have to give it 1/2 throttle and it backfires allot and pops and bangs to life the after 5-7 mins it settles down and runs semi smoothly but rocks back and forth a good bit
87 GMC V1500 305 700R4 NP208 and 10 bolts front and rear
Re: why does my truck run the way it does?
« Reply #1 on: April 11, 2012, 02:57:11 pm »
Do you have a check engine light on?
« Reply #2 on: April 11, 2012, 03:01:52 pm »
no i did but that was a sensor that wasnt hooked up so it hasnt come back
« Reply #3 on: April 11, 2012, 03:10:15 pm »
Weak fuel pump/low fuel pressure will cause that.
« Reply #4 on: April 11, 2012, 03:14:29 pm »
Check the fuel pressure, EGR operation and engine compression; replace the fuel filter and give it a tune-up.
« Reply #5 on: April 11, 2012, 03:35:24 pm »
ok i will start to work down that path
Offline thirsty
    • Suitor's Garage
« Reply #6 on: April 11, 2012, 05:02:05 pm »
I would check the timing on it.
Offline 454Man
  • Why Race?
« Reply #7 on: April 11, 2012, 05:38:07 pm »
If I remember correctly isn't the timing controlled by the computer on a tbi? I remember something about unplugging a brown wire to check timing on a friends truck.
Sent from my T-Mobile G2 using Tapatalk 2
« Reply #8 on: April 11, 2012, 06:24:33 pm »
the compression is either 175 or 180 alternating cyclinders
Offline Da67goatman
  • Burban
« Reply #9 on: April 11, 2012, 10:40:39 pm »
The timing is electronically advanced or retarded, but you still have to time it to 0* before any of that takes effect.
<Pitcrew>
Offline 454Man
  • Why Race?
« Reply #10 on: April 11, 2012, 10:42:51 pm »
Ok so on a tbi do you have to disconnect the brown/ tan wire
and then set the timing?
« Last Edit: April 11, 2012, 10:48:25 pm by 454Man »
« Reply #11 on: April 12, 2012, 12:01:35 am »
Checking/setting base timing on TBI fueled 305s/350s involves running the engine to operating temperature, then unplugging the timing connector (single brown wire with black stripe) that breaks out of the engine harness near the bulkhead plug below the brake booster, forcing the Electronic Spark Timing (EST) into bypass mode.  Unplugging the timing connector will illuminate the Check Engine light and set code 42.  Cycling the key after reconnecting the timing connector will return timing control to the EST system and extinguish the Check Engine light.
« Reply #12 on: April 12, 2012, 06:32:30 am »
     You said you checked the engine compression, but these other items need to be done and more than likely will solve your problem.
« Reply #13 on: April 18, 2012, 05:00:58 pm »
Ok it rained today and i went to check the timing and i disconnected the electronic spark control wire and i fired up and ran perfect what gives, it has never ran like this ever before.
« Reply #14 on: April 18, 2012, 05:52:56 pm »
Did the Check Engine light come on when you disconnected the EST?
« Last Edit: April 18, 2012, 05:55:08 pm by bd »
