Author Topic: Question about lifting an 87 C-10  (Read 11401 times)
Offline danielM87
« on: September 24, 2004, 08:27:00 pm »
I own an 87 custom deluxe with a 350 bored V-8 with open headers. I have found 2 lift kits for it on the internet (took me forever to find). One is a 3 inch body lift, the other is a 4 inch suspension lift. my truck is 2 wheel drive (pitiful ,yes, i know), but i want to lift it!!! Which, or both, lift should i go with??? i think that having both them on at the same time would be AWESOME! my plans afterward are fitting the biggest tires possible onto it, so that should 100% influence the choice in lifts (or both of them together, if possible). how big of tires do you think i could go?
e-mail me or make a post!!
khsuglykid89@hotmail.com
link 3 inch BODY lift
www.jcwhitney.com/autopar...pId-433927
link 4 inch SUSPENSION lift
www.jcwhitney.com/autopar...pId-437770
Offline roundedline
Re: Question about lifting an 87 C-10
« Reply #1 on: September 27, 2004, 01:45:00 pm »
The 4" suspension lift is for a 4x4 (K-series) truck, so it won't work with yours.  The body lift I guess can be used, I have just never done it.
This company has lift kits for 4x2's though.
www.fabtechmotorsports.co...87c10.html
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline danielM87
THANKS A BUNCH!!!
« Reply #2 on: September 27, 2004, 05:39:00 pm »
Thanks a lot for the info. I dont know if JC Whitney is correct or not, but the page said that it was for C and K model pickups. I have a feeling your going to be right about what you said, im just wondering....take another look and where it says "Model" , it says C/K pickup. Anyhow, i checked out that site u gave me...pretty neat, exactly what ive been looking for, only problem is that i cant buy anything from them online, and they provide no info on a store location. I've officially been searching for 2 months for a lift kit for that truck now. (officially unsuccessful as of now) hehe. :rollin
write back!
Offline roundedline
Re: THANKS A BUNCH!!!
« Reply #3 on: September 27, 2004, 05:43:00 pm »
Yeah, I noticed they labeled it C\K, but that is incorrect.
This is where you can buy online from Fabtech:
www.fabtechmotorsports.co...talog.html
Project Su
Jimmy 2WD Project
Offline danielM87
your right
« Reply #4 on: September 27, 2004, 05:59:00 pm »
I just called the JC Whitney customer serv. guys and they said its only for 4WDs. You were right:b
I just ordered that catalog, thanks.
Offline Dark Horse
Re: your right
« Reply #5 on: September 30, 2004, 12:52:00 pm »
Fabtech 4" Long Arm obviously adresses the front, but what about the rear?
Long arms and triangulated axle?
Offline roundedline
Re: your right
« Reply #6 on: September 30, 2004, 05:46:00 pm »
To lift the rear you can use the same stuff the 4x4's use.  Lift leaf springs or blocks if you don't get out of hand with them.  Personally I would go with the springs.
Project Su
Jimmy 2WD Project
Offline Dark Horse
Re: your right
« Reply #7 on: October 01, 2004, 01:25:00 am »
With the rear - where should I look to find them?  Do you recommend revolving shackles?
Also - while the 4" LA lift should conceivably clear 34's - what size can fit in the fenderwells?
Edited by: Dark Horse at: 10/1/04 7:13 am
Offline roundedline
Re: your right
« Reply #8 on: October 04, 2004, 03:17:00 pm »
33x12.50 will fit without trimming, anything larger and you will have to start cutting body panels.  The Long travel from Fabtech is for 33" tires.
You can get springs for the rear at a good 4x4 shop.  Blazers come with the longer springs, but pickups only had them on the HD rear spring setup.  Also a 4x2 has different shackles than a 4x4.
Project Su
Jimmy 2WD Project
Offline 1976Scottsdale
Re: your right
« Reply #9 on: October 04, 2004, 09:22:00 pm »
JCWhitney carries a 3" body lift for your tuck for around 100.00, and a 2 inch suspension lift for 154.99.  I was going to do both to my 76 Scottsdale C10, but instead, I bought a 79 k10 silverado from a neighbor for 100.00 and swapped bodies.  Now I have a 77.5 K10 Scottsdale...lol.  What gears are you running?  3.07, 3.73, 4.11?  If you are under 4.10, running 33's is about it for you, your rearend will have a tough time turning anything bigger.
Offline danielM87
how...
« Reply #10 on: October 18, 2004, 04:21:00 pm »
How on earth would i go about finding out what gears i'm running? The VIN? Original everything and i dont see how anyone could know what gears they run unless theyve put new ones on....?:eek
87' C-10
Offline roundedline
Re: how...
« Reply #11 on: October 18, 2004, 10:38:00 pm »
I don't have the book to decode them, but there are marking on the axle that designate the gearing that is "supposed" to be in there.  This is assuming that a truck 20 years old is still completely stock.  You also can pull the diff cover and look at the ring gear.  It is marked on there.  Perfect opportunity to change that old Diff fluid.
Project Su
Jimmy 2WD Project
Offline danielM87
__
« Reply #12 on: October 29, 2004, 09:40:00 pm »
I found this 2 inch suspension lift that indeed fits 2WD trucks  -  www.jcwhitney.com/autopar...pId-444540
That, along with a 3 inch body lift will do just fine clearing 35s, or will it?
The fabtech people are hard to order from, you must buy their catalog, wait for shipment, order from the magazine, and so on , when you could just do easy transactions online.
