Author Topic: body shells  (Read 5942 times)
Offline 77 cc lb
body shells
« on: May 23, 2012, 03:33:40 pm »
 I am planning on buying a parts truck and a suburban, to later become a parts truck. Would it be better to just scrap the shells and misc. parts or is there a demand for the shells since i will be using most of the of the truck? going to be using the doors, interior and engine out of sub. and the bed and front clip off the truck. Any suggestions would be appreciated, I don't know the market for this kind of stuff. Thanks
87 Chevy crewcab shortbed soon to have a 454/400
Offline Elpresidente
Re: body shells
« Reply #1 on: May 23, 2012, 10:14:51 pm »
If you have the space to put it aside i'm sure someone would want to make a project out of it in the future.
I find that any parts I throw away, someone will either be looking for it shortly after or i'll discover a use for it. its a real PITA.
'82 Chev Scottsdale
Proud to be Canadian \m/
Offline slammed79
  • Thou shalt not drive stock
Re: body shells
« Reply #2 on: May 24, 2012, 12:34:54 am »
Where are you located? Are these shells rust free?
Praise the lowered
Re: body shells
« Reply #3 on: May 24, 2012, 08:51:23 pm »
     Depends on if you have space like Elpresidente said, also if they are rust free like slammed said you can get some money from someone needing a rust free shell.
Offline werewolfx13
Re: body shells
« Reply #4 on: May 25, 2012, 12:49:44 am »
After removing the doors from the burb, I'd mount your old doors on it with some matching keys, make the glass a bit more secure with contact paper on the inside, followed by welded wire fence screwed to the sheetmetal above and below the windows, and use it for storage space   ;D
Chris
'83 Chevy c10 Silverado SWB
Offline 77 cc lb
Re: body shells
« Reply #5 on: June 04, 2012, 05:35:55 pm »
Thanks for the info guys. The sub turned out to be a keeper, cleaner than I anticipated. And the truck is going back to the owner when I get done pulling what I need off of it. Thanks again.
