Author Topic: cab lifting question  (Read 4006 times)
Offline 81GMCBILL
« on: October 09, 2012, 10:12:38 pm »
Would it hurt/dent any of the top of the cab if i lifted up with straps through both door openings?
could the top handle the weight ?
thanks for your help?
85 GMC K25 4X4 383/th400/np208
Re: cab lifting question
« Reply #1 on: October 10, 2012, 12:12:46 am »
Straps can dent the edges of the roof, plus the pinch weld can damage straps. I use a 4"x6" with a long eye bolts through each end. Use a couple pairs of Vise Grips on each side to keep the beam as far forward as possible in the door hole, so that the weight is a little better distributed.
Offline 81GMCBILL
« Reply #2 on: October 10, 2012, 08:26:12 pm »
I see - thats a good idea - i have alot those type of beams so thats what im goin to do.
thanks much !
