Fuel Systems and Drivability
85 TBI with I think a 305? Cranks fooooorever
Topic: 85 TBI with I think a 305? Cranks fooooorever (Read 26922 times)
winky
Re: 85 TBI with I think a 305? Cranks fooooorever
Reply #15 on:
October 24, 2012, 11:38:04 am »
If you have a test port I usually charge $10 to check fuel pressure ( shop will probably be $45) if it is that then your looking at a fuel pump
Reply #16 on:
October 30, 2012, 10:30:05 pm »
The regulator/diaphram on the back of the TBI keeps the pressure in the system and bleeds off any excess above set pressure. A TBI won't have a Test port, you can probably rent the tool (or maybe have them check it) at any parts store.
