Author Topic: 83 Silverado Guages  (Read 5556 times)
Offline hoyle83
83 Silverado Guages
« on: November 01, 2012, 10:26:01 am »
Hey there,
Just in the midst of building my 83 reg cab short box k10 with a rebuilt 700r4 and t-case as well as a new crate gm goodwrench small block 350/290 horse. The truck comes with an electrical oil pressure guage that wasn't working, temp guage that i have a new sender but the guage is screwy, battery guage and a clock that work fine. I would like to have true readings off this new mill in the heat and oil pressure department and was told to use a mechanical oil pressure guage and sender... I understand that you can buy many types of guages that can be installed under the dash or something but i was curious whether anyone can give me the brand and or part number for aftermarket mechanical guages that will fit pretty with not too much modification? Thanks in advance guys.
Mitch Hoyle
Bridgenorth,Ontario,Canada
Mitch Hoyle
KCCO
"Work Hard To Play Hard....Or To Fix Your Toys....And Then Play Hard!"
Offline blazing816
Re: 83 Silverado Guages
« Reply #1 on: November 08, 2012, 02:28:53 pm »
Here's what I did to my beater truck it was a cheap nice looking solution, I think. My ground up build I will probably using Dakota gauges, but if your just replace one or want a cheap fix read my thread below.
http://forum.73-87chevytrucks.com/smforum/index.php/topic,24709.0.html
Offline hoyle83
« Reply #2 on: November 13, 2012, 09:28:10 am »
Thanks a ton 816, was teh 2" tach sunpro as well??
Mitch Hoyle
KCCO
Offline blazing816
« Reply #3 on: November 13, 2012, 02:32:46 pm »
No I think they only make a 3" (which I have also but was too big for that spot). So I went to a store here a bought a 2" tach from them for like $25. It bums me out a little cause the bezel is grey plastic instead of the chrome bezel of the Sunpor, but becuase it was in my beater did not bother me too much. You can order it online if you do not have a store by you (you can change color of little buy a press of a button:
http://www.harborfreight.com/2-inch-led-lit-tachometer-98480.html
