Author Topic: need a little help with a NP205 shifter...  (Read 4262 times)
Offline gmachinz
« on: November 01, 2012, 06:16:30 pm »
I am missing the bracket and wire harness @ the shifter for the 4x4 indicator in the cluster. I have the part of the harness from the cluster down to the shifter but the project truck I got is missing it @ the shifter. If anybody has an exploded view with part numbers let me know!
« Last Edit: October 09, 2014, 09:54:32 pm by Captkaos »
Offline nvrenuf
  • Bazinga!
    • Project Pics
Re: need a little help with a NP205 shifter...
« Reply #1 on: November 09, 2012, 12:54:34 pm »
I don't have an exploded view but the 205 indicator switch screws directly into the top of the case, it's not located on the shifter.
John
'91 K5 454, 4spd, Dblr, J76, 70HD, 5.86's & 43's
'06 Dodge MegaCab
'06 Jeep Rubicon Unlimited
« Reply #2 on: November 10, 2012, 06:58:37 am »
What nverenuf said.
Its just a spring loaded ball switch. When the case is shifted into any 4x4 position a rail inside pushes it close completing the circuit, lighting the light.
The shifter just has a pass through bolt sometimes with a greaes fitting in the head of it and a grease passage drilled down through and out the side of the bolt.
