Author Topic: Rebulding My 78 K30 Wrecker  (Read 16951 times)
Offline ralphhemi
« on: November 06, 2012, 08:46:38 pm »
Short on time, trying to rebuild rip-van winkle before snow fall. So far removed hood ,inner and outer fenders, cab. Replaced exhaust man flow gaskets ,changed valve cover gaskets Tomorrow going to replace the clutch,and transmission the old one pops out of third  it is a ms 465 ,Photos to follow
Ralphhemi
Offline ralphhemi
« Reply #1 on: November 17, 2012, 06:51:18 pm »
 :) ;) :D ;D  Trying to get this rebuild done before snow fall, cab swap, change transmission new clutch, rebuild front drive shaft, replace  rear pinion seal, new duel exhaust
Ralphhemi
Offline thirsty
    • Suitor's Garage
Re: Rebulding My 78 K30 Wrecker
« Reply #2 on: November 17, 2012, 08:24:53 pm »
A K30 wrecker.......drool!
Offline ralphhemi
« Reply #3 on: November 20, 2012, 06:33:44 pm »
« Last Edit: November 20, 2012, 07:05:44 pm by ralphhemi »
Ralphhemi
Offline ralphhemi
« Reply #4 on: November 20, 2012, 06:49:44 pm »
1973 cab I'm installing
« Last Edit: November 20, 2012, 07:06:16 pm by ralphhemi »
Ralphhemi
Offline ralphhemi
« Reply #5 on: November 20, 2012, 06:52:08 pm »
Converting cab from two wheel drive to four wheel drive. New higher transmission hump
Ralphhemi
Offline ralphhemi
« Reply #6 on: November 20, 2012, 06:54:14 pm »
Pic of good used MS465 with new clutch installed also rear main seal
« Last Edit: November 20, 2012, 07:05:08 pm by ralphhemi »
Ralphhemi
Offline ralphhemi
« Reply #7 on: November 20, 2012, 07:13:36 pm »
Frame cleaned and painted. Also new rear springs
« Last Edit: November 20, 2012, 07:21:15 pm by ralphhemi »
Ralphhemi
Offline ralphhemi
« Reply #8 on: November 20, 2012, 07:16:42 pm »
This is what happens when you install a 283 pan on a 400 small block. You have a oil leak that looks like a rear main
« Last Edit: November 20, 2012, 07:20:30 pm by ralphhemi »
Ralphhemi
Offline ralphhemi
« Reply #9 on: November 21, 2012, 07:01:58 pm »
 :) ;) :D
Ralphhemi
« Reply #10 on: November 22, 2012, 06:17:30 am »
     Got any pics of what the truck looks like ?
Offline ralphhemi
« Reply #11 on: November 22, 2012, 07:00:05 pm »
Here's what it looks like with the cab on the frame. Give us a few more days and I'll put up pics with the fenders and hood on it
« Last Edit: November 22, 2012, 07:02:27 pm by ralphhemi »
Ralphhemi
Offline ralphhemi
« Reply #12 on: November 22, 2012, 07:08:46 pm »
This is what we ran into when we put a 73 c10 cab on a 78 k30 frame. We had to change the transmission hump, cut the dash wider for the heater controls, cut the dash for the wiper switch, the heater box was different so we swapped that over, relocate the seat belt holes because 73 had a lap belt and the 78 had a shoulder harness seat belt.
« Last Edit: November 22, 2012, 07:14:20 pm by ralphhemi »
Ralphhemi
Offline thirsty
    • Suitor's Garage
« Reply #13 on: November 22, 2012, 07:17:50 pm »
Keep up the good work! Progress always seems to get some of us motivated to do more to our projects. :)
Offline ralphhemi
« Reply #14 on: December 10, 2012, 07:04:13 pm »
Before pics
« Last Edit: December 10, 2012, 07:10:19 pm by ralphhemi »
Ralphhemi
