Author Topic: Brake Caliper issue  (Read 9027 times)
Offline smfreema
Brake Caliper issue
« on: November 24, 2012, 03:40:57 pm »
i bought a used set of 2.5 Western drop spindles for my 84 chevy truck. I dont think the stock brake calipers will fit correctly? Bolt holes aren't lining up? Same 1.25 rotors where on these spindles....Any recommendations?
Am i missing something? Please help!!!
Thanks
Offline smfreema
Re: Brake Caliper issue
« Reply #1 on: November 26, 2012, 06:35:00 am »
Let me ask this....do different year trucks have different calipers? Could i have spindles from truck pre 81 and my 84 calipers wont fit? Or could i have calipers on this truck that are different? Could i have wrong spindles? They bolt up fine? I put new ball joints on....I"m not sure where to start figuring this out as no one seems to know...Any insight appreciated..
My caliper bolt holes are not lining up by a good 1/4 inch....
« Reply #2 on: November 30, 2012, 07:42:02 pm »
Pre 1980 1/2T trucks only came with HD 1.25" rotors, 81-87 had 1" or 1.25.  The brake lines should work.
Offline 84burb
« Reply #3 on: December 01, 2012, 09:41:31 am »
Looks like you've got some research to do.  :o
I don't know what your truck is but I'm going to assume 1/2t.
Western lists separate part numbers for the 73-87 C10
1" rotor - 2 1/2" drop (part # 13200)
1 1/4" rotor - 2 1/2" drop (part # 13100)
There is also a different part number for 88-91 C1500 - 2" drop spindles. (part # 12400)
The C3500 series have different spindles also.
73-87 - 3" drop (part # 13600)
89-99 - 2" drop (part # 13700)
I see 4 different applications for calipers on 2wd 1/2t pickups 73-87.
73-78
79-80
plus 81-87 have 2 different caliper apps depending on rear brake size
88-91 have 3 different caliper apps depending on the production option.
Clear as mud? ???
Sorry I couldn't be more help but you are going to have to get more info on what you actually have in hand.
Casting/part numbers on your spindle and a call to Western Chassis (Tech 888-999-9139) may give you the info you need.
Remember, Google is your friend. Major auto parts sites are great for finding what stock part numbers interchange with a little time searching.
I just realized, I've become one of those Ol' Geezers I didn't need to listen to when I was young.
Use what you can and leave the rest as your mileage may vary.
84 - Suburban Silverado package 1/2 ton - 2wd 5.7 - 4sp AOD
77 - C10 Stepside Parts Truck
