Author Topic: np203 k10 blazer  (Read 6314 times)
Offline jeffaj01
np203 k10 blazer
« on: November 26, 2012, 08:31:42 am »
I found a th350 with an np203 transfer case mated forsale in my area. Is there a difference in the transfer case out of a 4x4 pickup and a k10 blazer? Mine seem to be acting goofy bouncing out of gear, and these are supposed to be ok. I'm sure this is the combo I already have, so I'm looking to just swap the pair out quick and easy. What would a decent price be to pay for this pair?
Jeff
Re: np203 k10 blazer
« Reply #1 on: November 26, 2012, 10:03:44 am »
     They are the same.  You said yours was bouncing out of gear, which one transmission or transfer case ?
     Both can be adjusted, you should try this first instead of just throwing another set in there.
Offline jeffaj01
« Reply #2 on: November 26, 2012, 07:26:38 pm »
It's got no front driveshaft in It, so I can throw it into 4 hi, I think. And it wont move for a while, then when it does it will just quit moving all together
« Reply #3 on: November 26, 2012, 08:58:55 pm »
     Have you checked fluids in both ?
Offline jeffaj01
« Reply #4 on: November 26, 2012, 09:10:52 pm »
Checked it in the trans, seemed fine, didn't check the transfer, have never had to real with a tc,
Offline jeffaj01
« Reply #5 on: November 26, 2012, 09:16:48 pm »
Reckon this spring I will change the trans fluid and filter, and change the fluid in the transfer. Hopefully that will help. I just found these at what I thought was a decent price, and mine seem to be wishy-washy. Thanks for the replies
« Reply #6 on: November 26, 2012, 10:06:26 pm »
Unless your NP 203 has been converted to part time it will not work without the front drivesahft installed.
