Author Topic: No start, No SES, No headlights, No horn  (Read 7050 times)
Offline kota4bye
« on: February 02, 2013, 11:18:52 pm »
Help.  Sorry to make first post like this, truck is an 87 k5.  I need to have this thing running like yesterday.
Truck ran and died as I was parking it.
Now I have none of the stuff in the title. It will crank, but the fuel pump is not running when I turn the truck to run. Jump the relay and pump runs.
So I know that the problem for starting the truck is getting power from ECM to the relay, but I seem to have no power anywehre.
All the fuses are good. I've replaced or bypassed all the fusible links....
Replaced the ignition control module.
There was an alarm, I removed it. The crazy thing was that when I was messing with that, it did go into alarm mode, and triggered the hazards while I had the truck in run, I could hear the fuel pump priming each time the hazards and headlights flashed....cant make that happen now though.
Re: No start, No SES, No headlights, No horn
« Reply #1 on: February 03, 2013, 10:08:53 am »
Welcome to the site from California.
Check/inspect connections through the bulkhead connector in the driver side firewall.
« Reply #2 on: February 03, 2013, 10:41:52 am »
What do you mean you bypassed your fusible links? That's a big mistake#1. Go back and add the proper circuit protection then recheck the ecm fuses. Get rid of all of that alarm crap and rewire it accordingly then follow diagnostic flowchart A-1.
« Reply #3 on: February 03, 2013, 10:43:41 am »
If you search cranks but will not run you will find similar posts as well
http://forum.73-87chevytrucks.com/smforum/index.php/topic,17537.msg140069.html#msg140069
