Author Topic: Transfer case spline seal  (Read 6202 times)
Offline pedigo78
  • Big Blue
« on: February 18, 2013, 02:28:32 pm »
So does anyone one know where i can buy a spline seal for my np205. its a little rubber seal that fits between the yoke seal and the yoke itself. it has the same amount of grooves as the shaft that way it fits all the grooves of the shaft. I need one
Sgt Pedigo USMC
Offline pholliday1
  • 1990 V3500 Crew Cab
Re: Transfer case spline seal
« Reply #1 on: February 18, 2013, 04:45:28 pm »
Should be able to source one locally? If not call Randy's ring and pinion sorry don't have number just google it
Offline pedigo78
  • Big Blue
« Reply #2 on: February 18, 2013, 06:40:22 pm »
Yeah the only way i can find one is by buying a transfer seal kit, but of course i dont need the whole kit. starting to upset me. I even called AAMCO to see if they had spline seals and nope sure dont. Ill try to look at randys
Sgt Pedigo USMC
Offline pedigo78
  • Big Blue
« Reply #3 on: February 18, 2013, 11:46:03 pm »
Found a spline seal or washer. If you have a NP205 or any transfer case issues, check out quad4x4 for parts.
Sgt Pedigo USMC
Offline Engineer
« Reply #4 on: February 22, 2013, 11:55:52 am »
Did you find one yet?
I probably have a spare you can have.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline pedigo78
  • Big Blue
« Reply #5 on: February 22, 2013, 09:11:48 pm »
sure did, got it off quad4x4 pretty good site for transfer cases. thanks a bunch
Sgt Pedigo USMC
