Author Topic: NP205 transfer case front yoke  (Read 9006 times)
Offline pedigo78
  • Big Blue
« on: February 21, 2013, 09:39:27 pm »
ok so i was doing some research about np205 trying to see if a spline seal goings on the front yoke as well as the rear. From what i have been reading and the diagrams the rubber spline seal only goes on the rear yoke not the front. So does a spline seal go on the front too?
Sgt Pedigo USMC
Offline Engineer
Re: NP205 transfer case front yoke
« Reply #1 on: February 22, 2013, 12:04:13 pm »
I don't know of a seal for the front. The rear is a 32 spline. Your front will either be a 10 spline (yoke), or a 30 spline (companion flange).
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline pedigo78
  • Big Blue
« Reply #2 on: February 22, 2013, 09:13:05 pm »
yeah this weekend i am going to pull the shaft down and put a output seal on it, so hopefully that will take care of it
Sgt Pedigo USMC
Offline pedigo78
  • Big Blue
« Reply #3 on: March 01, 2013, 06:35:56 pm »
well i have a 10 spline front shaft. pulled the driveshaft off and the yoke. going to replace the seal. its either that seal or the two slide rod seals. and i am pretty sure i have to pull apart the whole case to replace those.
Sgt Pedigo USMC
Offline Engineer
« Reply #4 on: March 02, 2013, 08:25:40 am »
It is rare that the shift shaft seals leak. But if they do you can replace them in the truck. It is a pain but it can be done.
Offline pedigo78
  • Big Blue
« Reply #5 on: March 02, 2013, 10:05:35 am »
ok, thats good to know. i hope your right about the seals still be good. yeah i figure a small pick would help pull them out
Sgt Pedigo USMC
Offline pedigo78
  • Big Blue
« Reply #6 on: March 08, 2013, 07:37:38 pm »
Got the front output shaft seal replaced. No more leaking thank God. I left the front drive shaft off while i went for a drive to ensure it was good after a drive.
Sgt Pedigo USMC
