Author Topic: front axle u joints  (Read 9624 times)
Offline rusty but trusty
front axle u joints
« on: February 22, 2013, 09:17:18 am »
I have a 87 gmc v1500 and i go to votech and I'm doing balljoints and the front u joints are not too bad yet but i have the new ones and would like to change them but my teachers is telling me that the chances of getting old ones out without breaking axle shafts is very slim. does anyone have a idea that will get them out without breaking shafts. also they are the original u joints  ???  and i don't reely have the money to buy new shafts
87 GMC V1500 305 700R4 NP208 and 10 bolts front and rear
Offline Sartobuilt
Re: front axle u joints
« Reply #1 on: February 22, 2013, 11:46:13 am »
That would be silly to not replace them while you have it apart. you have to pull the shaft to remove the knockle to do the And you have the new ones already.  Never had a problem, or herd of, the shaft breaking while trying to change them.
Offline Engineer
« Reply #2 on: February 22, 2013, 12:00:28 pm »
If you break an axle replacing the u-joint you did something VERY wrong.
Replace the ujoint now, there is no reason not to.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline thirsty
    • Suitor's Garage
« Reply #3 on: February 22, 2013, 01:45:31 pm »
Your teacher is wrong. Changing a universal joint is mechanics 101. ??? They are made to change.
« Reply #4 on: February 28, 2013, 07:04:05 am »
Your teacher is wrong. Changing a universal joint is mechanics 101.  They are made to change
Thirsty i agree with you it went fine
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #5 on: February 28, 2013, 11:39:56 am »
I am assuming your using u joints that are greasable? if so.... make sure when you press in the new joints that the zerk fitting is indexed so that when the axle is put back in the truck that you have easy access to the grease fitting. If you point the zerk fitting the wrong way it just makes greasing access that much harder.. just some insight from past mistakes..
