Author Topic: Engine knock..  (Read 3737 times)
Offline lifted87
Engine knock..
« on: April 19, 2013, 12:52:15 pm »
After searching the forum I didn't really find anything like my issue.... My stock 350 TBI has 110k on it and after sea foaming it I changed the plugs, wires, dist cap and oil. The truck knocks under a load but I cannot hear it while driving unless while slowing down the trans down shifts it will knock. It does seem to be rpm related as it knocks faster the higher the rpms... I recorded a video and hopefully you can hear what I'm talking about.
0:17 and 0:29-37 you can really hear it..
http://www.youtube.com/watch?v=NNlHqpLQTf4&feature=youtu.be
'87 4x4 350v8 6" suspension 35x12.50 A/T's. Dual exhaust,Flowmaster 40 series mufflers.
Built not Bought
Re: Engine knock..
« Reply #1 on: April 19, 2013, 08:42:00 pm »
Sounds like a rod.   :(
« Last Edit: April 19, 2013, 08:45:01 pm by bd »
Re: Engine knock..
« Reply #2 on: April 20, 2013, 07:06:20 am »
was it knocking before you changed the cap and rotor? or is the knock the reason you changed and sea foamed
Offline lifted87
Re: Engine knock..
« Reply #3 on: April 20, 2013, 09:38:38 am »
No it wasn't knocking before. I'm going to play with the timing and hopefully its a timing issue causing the knock.
Built not Bought
Re: Engine knock..
« Reply #4 on: April 20, 2013, 09:57:44 am »
yeah could be the distributor cap not seated right or its too far advance that would be the first thing i check. if it knocks under a load its points straight to timing
Offline lifted87
Re: Engine knock..
« Reply #5 on: April 22, 2013, 04:12:42 pm »
Quick update.... I was watching my oil pressure gauge and as it would fluctuate the knock would get worse. I was coming home from the gym yesterday and it pegged 0 psi as i was turning into my neighborhood and it was knocking like crazy so I thought well that's the end of that motor. Today I swung by advanced auto and bought a new oil pump for $22 bucks and thought what the heck might as well try it. Sure enough fired it up, knock, knock, knock, gauge pegged 30 and silence ever since!   So a 22 dollar pump, 15 dollars in oil and 10 bucks for a new pan gasket and so far so good.
Built not Bought
