Author Topic: Differential fluid  (Read 4255 times)
Offline Dszx13
Differential fluid
« on: June 12, 2013, 10:58:02 pm »
I have a Dana 44 front and a GM 12 bolt rear end out of a 75 pick up. It has 4.56 gears. Wandering what weight fluid I will need for both axles an how much I need to get as well
Sent from the legion of doom
84 K10 350/400 4.56 gears. 35 BFG all terrains
Old 93 ecsb
Re: Differential fluid
« Reply #1 on: June 12, 2013, 11:32:47 pm »
 80-90 gear oil GL5. and get one of those tops that screw onto the bottle with the long rubber hose. i think you need about 2.5 qts for the front and 2.5 for the rear
Offline Dszx13
Differential fluid
« Reply #2 on: June 13, 2013, 12:16:36 pm »
Ok cool. Thanks
Old 93 ecsb
