Author Topic: new here from minnesota  (Read 5373 times)
Offline ben h
« on: August 09, 2013, 09:21:52 pm »
figure i should make a post here i am from minnesota im 20 but this isnt my 1st 80s chevy iv had about 8 others but my current one is a 83 reg cab long box 8in lift in the front and 6 in the back ( still looking for rear lift springs) and just puting in a freshly built 383 will be back running in about a week or so blew the old motor valv broke off and put a hole in the cyl wall and snapped a conecting rod
i built the front bumper and there is a 12k lb badlands winch on the front with 50 ft of 7/16ths synthetic line
its got 3/4 ton axles with 4:10 gears and rear end is welded only things i still need for the truck are extended front brake lines and a drop pitman arm
this is how it sits right now
Re: new here from minnesota
« Reply #1 on: August 09, 2013, 09:34:14 pm »
Welcome from NW Indiana
« Reply #2 on: August 10, 2013, 12:30:51 am »
welcome from maryland. have you done a shackle flip yet?
« Reply #3 on: August 10, 2013, 01:25:26 am »
      Welcome from California.
Offline ben h
« Reply #4 on: August 10, 2013, 07:41:29 am »
no i havent wasnt sure if i wanted to do a shackle flip or just get 8in lift springs dont really need flex its just driven on the street and its my mudder
« Reply #5 on: August 10, 2013, 10:49:30 pm »
from what i understand the shackle flip and a 4" lift will give you a softer ride than a 8" all springs.
Offline ben h
« Reply #6 on: August 11, 2013, 07:40:59 am »
yea i know that part but with 8in springs up front i can make em compress like an inch wile jumping on the front bumper and i weigh 300 lbs so its just a rough ride no matter wat so a soft ride dont really bother me
Offline 1982 Daily Driver
« Reply #7 on: August 13, 2013, 07:23:32 pm »
Welcome from South Carolina.
« Reply #8 on: August 13, 2013, 11:11:53 pm »
you can take a spring or two out up front will help with ride and make your axle shafts last a little longer Click ME
