Author Topic: np205 question  (Read 4411 times)
Offline Big Daddy
np205 question
« on: August 23, 2013, 07:56:46 pm »
Will an input shaft from a 350 turbo/205 transfer case (1980 slip yoke 205) fit into a 205 that has the 10 spline input shaft?  I would prefer to swap the parts that I have before I go out and buy an adapter I might not need
Re: np205 question
« Reply #1 on: August 24, 2013, 12:09:55 am »
cant say for sure about the input shaft, but i know you can swap output shafts. so i would assume its the same, since the 10 spline and 27 spline use the same input shaft bearing
Offline Engineer
Re: np205 question
« Reply #2 on: August 28, 2013, 08:36:35 pm »
Yes you should be alright.
The 205s from a Turbo 400 had a larger input bearing, but the 205 case housing for the TH350, and SM465 applications were identical.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
