Author Topic: side windows  (Read 17074 times)
Offline Kingaling
side windows
« on: October 12, 2013, 02:21:48 am »
can you take out the side windows and remove them entirely and just use a single pane window?
if so what can year/make/model can i pull them out of?
i have an 86
1986 Chevy C-10 Custom Deluxe (work in progress)
Re: side windows
« Reply #1 on: October 12, 2013, 05:57:58 am »
you can remove them. but nothing stock will fill it in. you can buy a one piece window kit from chris for $675
Offline Kingaling
Re: side windows
« Reply #2 on: October 13, 2013, 08:59:51 pm »
Alright thank you
Re: side windows
« Reply #3 on: October 15, 2013, 04:39:20 pm »
As Irish said, this is a custom piece.  There is no donor that can be used to swap to a pickup.
Offline Jason Wiechec
Re: side windows
« Reply #4 on: October 17, 2013, 12:37:54 pm »
two of the guys from my club have them installed they look absolutely insane plus they quieted down the cab noise from the vent windows. it will be a great addition to your truck. I plan on adding them myself. also look at the rear window conversion.
Re: side windows
« Reply #5 on: October 17, 2013, 10:57:07 pm »
but you lose the ac effect. you know you open the vents so they blow right up your shorts
Offline frotosride
    • WFO CONCEPTS
Re: side windows
« Reply #6 on: October 18, 2013, 09:14:37 pm »
Tre but as you get older all that wind noise gets annoying!  I plan on ding this and trying my luck getting a piece cut and making a brace for the lower mirror mount. If not then Maybe weld up a patch for that upper corner, mount a modern mirror on it and use a factory window.
Offline frotosride
    • WFO CONCEPTS
Re: side windows
« Reply #7 on: October 18, 2013, 09:15:19 pm »
Man I wish I owned a scrap yard.
Re: side windows
« Reply #8 on: October 27, 2013, 02:01:50 pm »
you can't cut curved safety glass..
Offline frotosride
    • WFO CONCEPTS
Re: side windows
« Reply #9 on: October 28, 2013, 04:11:27 pm »
Good to know before I tried that. I should know this considering what happens when they shatter in your face. Didn't think about that until just now.
Re: side windows
« Reply #10 on: October 28, 2013, 07:20:26 pm »
This is you only option.  I had all the templates ready to be built in 2002, but the price stopped me.  Plus this design is MUCH better..
Offline 75_chevy
Re: side windows
« Reply #11 on: February 07, 2014, 12:45:18 am »
any more pics of the single pane installed? looks neat
Offline Greybeard
Re: side windows
« Reply #12 on: February 07, 2014, 03:56:54 pm »
Well Capt'n I have seen curved safety glass get cut. I won't say it's easy and the guy doing the cutting told me it would be mighty expensive. He was right. Out of three $100 sheets of glass he got one to cut. He would use the same trick as cutting flat safety glass. I wasn't paying for this little trick. My boss needed a really custom piece of glass for some artwork type safety window he had have built for a project and a piece of Buick side window glass had the necessary contours. Don't ask, I don't know why he didn't just have a piece custom made from scratch, he was good at spending a dollar to save a dime. But they scribed it laid the full of lighter fluid and lit it, and scribed it again and lit it again. Like I said, the first two didn't work. They almost worked but the last little bit would always leave the scratch mark. Of course the cut wasn't straight either.
Re: side windows
« Reply #13 on: February 18, 2014, 08:50:11 pm »
This is them in my 1989 Blazer that I am converting to 2WD:
As Irish pointed out, these are in the site store.
Re: side windows
« Reply #14 on: February 18, 2014, 08:58:09 pm »
Can you get them with shaded glass?
