Author Topic: bench seat brackets bent  (Read 11947 times)
Offline jaime
« on: November 13, 2013, 01:07:54 am »
Bought a bench  seat but when I bought it I didnt notice the front of the bracket were the holes r were bent up wards  how do I go about bending them back should I beat them back in place if anyone has had this problem pls help
Offline 81_Chevy
Re: bench seat brackets bent
« Reply #1 on: November 13, 2013, 08:35:03 am »
do you happen to have a BFH laying around?  ;D
Offline jaime
« Reply #2 on: November 13, 2013, 08:30:28 pm »
Yes I do
Offline 81_Chevy
« Reply #3 on: November 14, 2013, 08:34:13 am »
that should do nicely. but if that doesn't work, try some heat from a propane torch, and if that still doesn't work you could try an oxy-acedline setup.
« Reply #4 on: November 14, 2013, 08:15:56 pm »
Depending on how bad if it is just the ends use a pair of pliers or a cresent wrench.
Offline jaime
« Reply #5 on: November 14, 2013, 11:22:15 pm »
Im guessing  since the seat wasnt in a truck and in his garage the sat on it and bent the front brackets bc ther bent upwards
