The Lows (Lowering/Drops)
Caster/Camber
Topic: Caster/Camber (Read 6200 times)
Copper Canyon
Caster/Camber
August 20, 2006, 07:15:00 pm »
I'm thinking of doin a 2/2 drop on my '86 swb c-10, but I think the 2" springs will mess with the caster and camber. Do you think it will make my front wheels tilt in a little?
autonuerotic
Re:...
August 20, 2006, 11:55:00 pm »
When I first lowered my truck I used a 3 inch Eibach lowering spring without any alignment or ride quality problems. You should be fine.
toplessblazer
Re: Re:...
August 21, 2006, 12:55:00 am »
Anytime you take your suspension apart and replace components you need an alignment. Don't try to save $50.00 by skipping an alignment because you will end up spending more than that replacing chewed up tires.
Copper Canyon
Re: Caster/Camber
August 21, 2006, 02:26:00 pm »
Thanks for the help guys, that makes my decision easier now. Now my choices are 2/2 or a 3/4. I want to keep my '86 classic, but with a modern twist. You know what I'm sayin.
autonuerotic
Re:...
August 21, 2006, 08:24:00 pm »
Maybe I didnt understand the question... It is correct you will need an alignment, what I was saying is that your truck will still be able to be within specifications.
Re: Re:...
August 26, 2006, 05:55:00 pm »
By placing in a shorter spring the camber angle will change more negative.
RSBAD454
Re: Re:...
August 31, 2006, 08:06:00 am »
when you are just adding dropped spindles, camber is not effected.....when you add dropped springs or cut coils from the stock springs, then you will change camber. I agree, always get alignment checked from a know shop that will deal with lowered vehicles.
Toys are my game
http://
Caster/Camber
