73-87 Chevy & GMC Trucks
1987 5.7L V8 fuel economy
Topic: 1987 5.7L V8 fuel economy (Read 4645 times)
paolotvl
December 20, 2013, 11:17:44 am »
I just put the first miles on my "new" 1987 Custome Deluxe 10 with the 5.7 liter V8 fuel injected. After the first 200 miles without pushing it, I'm getting about 9MPG. Is this normal? The engine seems to be running fine. Thanks for reading.
zieg85
Re: 1987 5.7L V8 fuel economy
December 20, 2013, 11:40:24 am »
Yikes only 9, I'd say no, you should be 15 minimum, my 454 carb'd gets 13 at least
December 20, 2013, 10:42:45 pm »
my 79 k20 with 38's 4.10 gears sm465 and 350 gets 9. make sure your tires are inflated right. keep her under 60 and you should see a increase. unless your speedo/ odometer is wrong
December 24, 2013, 11:32:09 am »
what was done to the motor? It should be getting at least 12-15mpg.
Stewart G Griffin
January 01, 2014, 10:29:46 am »
The first thing i would ask is how exactly are you calculating your mpg?
bake74
January 01, 2014, 10:34:50 am »
Quote from: Stewart G Griffin on January 01, 2014, 10:29:46 am
Also does it have stock tire size and gears ?
74 k10, 77k10 Tom
