Author Topic: 1987 5.7L V8 fuel economy  (Read 4640 times)
Offline paolotvl
« on: December 20, 2013, 11:17:44 am »
I just put the first miles on my "new" 1987 Custome Deluxe 10 with the 5.7 liter V8 fuel injected. After the first 200 miles without pushing it, I'm getting about 9MPG. Is this normal? The engine seems to be running fine. Thanks for reading.
Re: 1987 5.7L V8 fuel economy
« Reply #1 on: December 20, 2013, 11:40:24 am »
Yikes only 9, I'd say no, you should be 15 minimum, my 454 carb'd gets 13 at least
« Reply #2 on: December 20, 2013, 10:42:45 pm »
my 79 k20 with 38's 4.10 gears sm465 and 350 gets 9. make sure your tires are inflated right. keep her under 60 and you  should see a increase. unless your speedo/ odometer is wrong
« Reply #3 on: December 24, 2013, 11:32:09 am »
what was done to the motor?  It should be getting at least 12-15mpg.
Offline Stewart G Griffin
« Reply #4 on: January 01, 2014, 10:29:46 am »
The first thing i would ask is how exactly are you calculating your mpg?
« Reply #5 on: January 01, 2014, 10:34:50 am »
      Also does it have stock tire size and gears ?
