Author Topic: 86 c10 stock front spring length  (Read 6715 times)
Offline daman02
« on: September 21, 2006, 08:21:00 pm »
I ordered a drop kit for my truck and i was just wanting to know the stock length for the front springs so i can make sure i got the right ones before i stick them in.
'86 C10 Silverado 350 with 700r4 and 2500 stall
Dropped 2" in front and 2" in rear but soon to b 4" in rear
18x10 wheels with 295/45 18 tires
Offline roundedline
Re: 86 c10 stock front spring length
« Reply #1 on: September 21, 2006, 07:28:00 pm »
Comparing a brand new spring to one that is almost 20 years old isn't going to be a good comparison.  Plus the new ones will settle with time just like the old ones did.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline daman02
« Reply #2 on: September 21, 2006, 08:18:00 pm »
yes i understand that i just didn't clarify that i was needing the length of a new standard spring so i could make sure i don't have a 3" drop spring or something crazy.
Offline shaved80
« Reply #3 on: September 22, 2006, 02:22:00 am »
where did you order them from? if it were from a place where i had any doubt they were the right ones, i wouldn't order them
Offline lotopp79
« Reply #4 on: September 23, 2006, 08:27:00 am »
all palces make mistakes from time to time it is good to double check
Offline roundedline
« Reply #5 on: September 23, 2006, 11:37:00 am »
When you pull one side out, measure it against the new one.  That way you will now if it is lower or now against what you currently have.
Project Su
Jimmy 2WD Project
Offline 123 pugsy
« Reply #6 on: September 29, 2006, 06:46:00 pm »
I believe the thickness of the springs varies. A thicker spring won't give as much resulting in a higher stance.
Just something else you may want to check.
Pugsy
76 C10 LWB
TPI 350
