Author Topic: timing, TDC and distributor rotor  (Read 12887 times)
Offline gutts
Re: timing, TDC and distributor rotor
« Reply #15 on: March 09, 2015, 05:08:23 pm »
...I still would like to know about the TDC and rotor location.
The small block Chevy firing order is 1-8-4-3-6-5-7-2.  The crankshaft makes two complete revolutions for each cylinder to complete its intake-compression-power-exhaust cycle - the piston makes two complete down-up strokes per cycle.  As the crankshaft rotates, piston top-dead-center (TDC) occurs between the compression and power strokes, and between the exhaust and intake strokes.  Piston bottom-dead-center (BDC) occurs between the intake and compression strokes, and between the power and exhaust strokes.  The piston stops and reverses its direction of travel at TDC and BDC.  Ignition occurs directly between the compression and power strokes...
...intake stroke-(BDC)-compression stroke-(TDC)-ignition/power stroke-(BDC)-exhaust stroke-(TDC)-back to intake stroke, repeating cyclically...
Reiterating, a piston comes to TDC twice (two crankshaft revolutions) for each complete cycle.
Engine cylinders fire as opposing pairs or "running mates," as follows:
1 - 8 - 4 - 3
6 - 5 - 7 - 2
So, cylinders 1 and 6 are defined as running mates.  When cylinder #1 is at TDC compression/power, cylinder #6 is at TDC exhaust/intake, and vice versa.  In your posted images, cylinder #6 is near TDC compression, just beginning its ignition/power stroke; whereas, cylinder #1 is near TDC exhaust, just beginning its intake stroke.  Similarly, cylinders 8 and 5 are running mates, as are 4 and 7, as are 3 and 2.
Conceptualize the preceding description with a piston moving up and down in its cylinder to get the idea.
1 - 8 - 4 - 3
6 - 5 - 7 - 2
 Thank you for this . Now a question , as I am facing the front of the engine/truck , does the crank shaft turn clockwise or counterclockwise wise ?
Offline enaberif
« Reply #16 on: March 09, 2015, 05:34:04 pm »
Clockwise as can be seen with the fan.
Offline gutts
« Reply #17 on: March 09, 2015, 06:25:54 pm »
Thank you
