Brakes and Braking Systems
Brake line relocating bracket
Topic: Brake line relocating bracket (Read 12666 times)
Mattsfmj
January 31, 2014, 08:12:15 pm »
Hey everyone does anyone have the part number for a brake line relocate kit for a 1984 chevy with a 4 inch lift?
"I have a very strict gun control policy: if there's a gun around, I want to be in control of it."
- Clint Eastwood
1984 K10 step side
bake74
Re: Brake line relocating bracket
January 31, 2014, 08:54:57 pm »
Most lift manufactures have them, they might be listed as a accessory, did you check with them ?
74 k10, 77k10 Tom
firefighter
February 01, 2014, 12:31:32 am »
Are you wanting to do a relocate because the flexible brake line is now too short after adding the 4" lift kit?
If so, I had the same issue and just got longer flexible lines to the front calipers and rear splitter.
February 01, 2014, 04:18:50 am »
or did you go the cheap rout and not by extended brake lines?
firefighter
February 01, 2014, 07:19:27 am »
Quote from: Irish_Alley on February 01, 2014, 04:18:50 am
Ha Ha !!! I laughed out loud at this Irish
When I did my rebuild 2 years ago, the kit said it came with brake line brackets and I thought... great !!
It didn't take me long to figure out that I needed longer lines and was happy to just order some and fix the problem correctly the first time.
Mattsfmj
February 01, 2014, 02:58:38 pm »
Well not to tell a long story but so y'all know what I am doing. I had a friend who wreaked his 85 k10 about 2 months before I found the exact 84 I was looking for. So he had a 4 inch lift and 35x14.50 on his truck that was wreaked. I was able to buy the lift ,tires and rims off of him for $250 (I know great deal right?) any way I realized I forgot to get the front/rear brake relocate brackets off his truck when I took of the lift and it has already been junked. So I am trying to find the kit but have had no luck.
- Clint Eastwood
1984 K10 step side
February 01, 2014, 03:25:09 pm »
you can buy braided brake lines off parts stores or even rough county. im sure someone has the drop down bracket also
firefighter
February 02, 2014, 12:09:58 am »
Here are the front and rear extended brake lines that would fit your truck. $52 plus shipping.
They are stainless braided. They are what I used on my truck. I'm sure there are other sources but just wanted to let you know from someone first hand.
Good luck.
P.S. You got a great deal on the lift, tires and rims!!
http://www.roughcountry.com/extended-front-brake-lines-89340.html
February 02, 2014, 03:56:46 am »
i wana say when i got my rough country lift they actually sent skyjackers lines. this was over ten years ago
