Author Topic: Running like a turd  (Read 7220 times)
Offline kodalee
Running like a turd
« on: January 31, 2014, 08:34:27 pm »
I have a 1985 K10 with a Mr. Goodwrench 350. I have replaced the plugs and wires. Just rebuilt the carb. checked the manifold bolts those are all tight. When i give it gas you can tell it wants to run right but wont. it kinda sputters. no back fire. anymore questions please ask. I'm out of ideas and need help.
Re: Running like a turd
« Reply #1 on: January 31, 2014, 08:48:59 pm »
not enough info to form an opinion.  When hot?  when cold?  did it just start?  more info please
« Reply #2 on: January 31, 2014, 09:41:56 pm »
     Do you have a catalytic converter on your truck ?
« Reply #3 on: January 31, 2014, 11:16:35 pm »
did it start this after the tune up?
fuel filter?
timing?
are you sure its not a ford?
Offline kodalee
« Reply #4 on: February 01, 2014, 12:03:16 am »
Irish_Alley: It just started one morning out of no where, fuel filter is brand new, timing was set maybe two months ago and I promise it ain't a ford.
Bake47: I do not have cats on the truck. Will be putting headers and a full exhaust in a couple of weeks.
Zieg85: It does it hot or cold and seems to be doing it on the lower speed or i just cant hear it on the high way and it started about a week or so ago.
« Reply #5 on: February 01, 2014, 12:23:16 am »
make sure the distributor isnt loose and got a little retarded, also make sure a plug wire didnt become loose
Offline kodalee
« Reply #6 on: February 01, 2014, 01:30:34 am »
Irish alley thank you for all the help
Offline rich weyand
« Reply #7 on: February 01, 2014, 02:26:42 am »
Did you hook the vacuum advance to ported vacuum or manifold vacuum?
Offline kodalee
« Reply #8 on: February 01, 2014, 02:47:41 am »
What's the difference and where are they located
« Reply #9 on: February 01, 2014, 04:01:38 am »
on the carb. ported will be vacuum when you're on the gas and manifold is constant. if you feel vacuum on the port while at idle then you have found manifold is no vacuum then ported. its recommended to be ported on the advance for better emissions. but some people say its better for your truck to be on manifold
Offline rich weyand
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #11 on: February 08, 2014, 08:36:42 am »
X2
