Author Topic: Saginaw 3 spd floor linkage?  (Read 3168 times)
Offline 1over1
« on: February 23, 2014, 09:21:01 pm »
Hey all.
My truck has a #spd on the floor with a hurst shifter and my mechanic told me the linkage was all bent and boogered up. It's a 1980 Cheyenne but The tranny isn't stock and really not much is so I don't know if that matters. Anyway I wondered if there is anywhere I could get the linkage beyond ebay? There is one post on ebay that seems like a match but I'm new to this, my last vehicle I worked on was a buick GN and while it wasn't a lot newer it didn't have the same kind of problems. I was having to pull an Austin Powers and go make a 20 point turn when the linkage jammed and I'm now stuck in first...
Re: Saginaw 3 spd floor linkage?
« Reply #1 on: February 23, 2014, 09:23:22 pm »
JC Whitney sells a whole new set up
Offline 1over1
« Reply #2 on: February 24, 2014, 12:11:50 pm »
sick, thank you zieg85! I got it unstuck and once I lubed it up real good it feels a ton better. Gonna see how it does but if it stick again I'll snag them from jcwhitney!
« Reply #3 on: February 24, 2014, 01:00:11 pm »
No problem, if I ever can find OEM to put it back on the column on my 86 I'd give you the one that is in it...
