Author Topic: 700r4 trans line length?  (Read 3309 times)
Offline gotsmeuhh350
« on: February 24, 2014, 10:44:23 am »
I was just wondering if anyone knew how long the trans lines are. I've got a compression fitting on each line that's leaking, plus another leak on the clip of the oil pan. It's all ice and snow so I would like to spend the least amount of time under the truck as I can. Lol just so I can go in and get the right length the first time. If anyone knows it would save a lot of hassle. It's an 86 c15 rclb, 305 700r4. Thank you
87 V10, 350 T350, 2 3/4 stacks, stock tbi (sold)
86 K10, 350 T350, headers, edelbrock carb, duals (scrapped)
86 C10, rust free roller, (sold)
86 C15, 305 700r4, stock. everything. daily driver/project
Re: 700r4 trans line length?
« Reply #1 on: February 24, 2014, 06:23:31 pm »
     Are you wanting to replace them or fix them ?  It is kinda hard to know the exact length considering they are bent in several area's.
     You can buy kits to bend your own to match, or just buy them pre-bent.
     Or are you looking to just cut off the ends and fix them and see if there is enough length still to work that way ?  They do not leave much room on those lines to pull or stretch them out any.
« Reply #2 on: February 24, 2014, 06:46:21 pm »
I'd like to just replace them. I was just wondering if anyone had replaced them and knew what length they got is all. I was gonna get just straight tube and bend my own.
« Reply #3 on: February 24, 2014, 06:51:57 pm »
     In that case just hold on for awhile, there has been several members who have replaced their own lines with kits, give them a chance to see this thread and I am sure you will get a couple of answers of the kits they used and how much they needed, probably how much they had left over to.
« Reply #4 on: February 25, 2014, 02:57:43 am »
Alrighty, I will do that. Thank you
