Author Topic: Question on vacuum advance. Ported or Manifold?  (Read 3525 times)
Offline hondaman
« on: March 30, 2014, 02:43:32 pm »
Just to start off, thanks guys for answering the questions I've already asked.  It's helped me move along my quest.   :)
So now I'm dialing it in.
This is a new GM goodwrench crate motor on my 1981 c10 RWD.
Edelbrock dual plane intake (#3701) and mild cam.
Question is about the vacuum advance timing.
Per the internet, I unplugged and closed off every single vaccum line going to the carb.  I then set initial timing (10 degrees), idle speed and mixture.
According to the emissions sticker above the radiator, the distributor vacuum is getting it's vacuum source from the manifold (through all the EFE TVS stuff)  Well I deleted the EFE with my headers.  So now picking a vaccum source is rather straight forward.  A ported source on the carb, or the manifold.
Problem is, when I have everything dialed in, and then plug in the manifold source, it jumps my rpms by almost 400 (650 to 1050), which seems excessive to me.  Is that normal?  If that's the way it is, I wouldn't go back and reset my timing and idle after plugging in my vacuum advance would I?
Offline swilliams
Re: Question on vacuum advance. Ported or Manifold?
« Reply #1 on: March 30, 2014, 11:54:19 pm »
Its not a direct answer to your question but I got this link from one of the posts I have read on here.
http://www.digitalcorvettes.com/forums/showthread.php?t=75830
Offline hondaman
« Reply #2 on: March 31, 2014, 09:35:12 am »
That's some good reading, thank you.  I suppose I need to quit trying to do it like the factory had it setup, and learn to do standard chevy 350 tuning.
