Author Topic: Auto colum shift removal  (Read 5478 times)
Offline K10mashup350
« on: April 18, 2014, 12:21:42 pm »
So I'm now workin on my interior and another thing I need to address is the "shaft" for the auto shifter that's on the colum.... I know the easiest way to do this is change the colum to a standard one but in all the local scrap/pick n' pull yards there is only one... And if I took it I would loose my tilt and cruise.
I've tried knocking the pin out with no luck, just wondering if there's something I'm missin, an easier way to do this, or if I just need to keep trying to get the pin out...
Thanks
Offline jetmech
Re: Auto colum shift removal
« Reply #1 on: April 18, 2014, 04:09:14 pm »
If you are referring to the shift lever then it is held in with a pin that knocks out. If I remember correctly it has a small "flare" on the top side that will only let it come out by knocking from below. Perhaps this is to keep it from falling out. It also has a small amount of tension from the spring on the end of the lever.
'86 Sub and '86 SWB C-10
1990 454 SS
« Reply #2 on: April 18, 2014, 09:24:23 pm »
     Did you read through this thread yet ?  http://forum.73-87chevytrucks.com/smforum/index.php?topic=12525.0
« Reply #3 on: April 25, 2014, 06:00:25 pm »
No I was unsucsessful at pulling up anything in the search but I will read threw it for sure
